Question about Maytag Neptune MDE5500AY Electric Dryer
Noisy maytag neptune electric dryer
Im told it's the blower drum, but I can't get to it. the back is one piece of sheet metal that wraps around the whole dryer. I think there must be a way to see if it's the "D" piece of the drum as I was told.. any suggestions would be great. thanks so much
  • sharanny Jun 22, 2009
    Well, you might be able to tell from my post that Im a woman, and not very strong so this is a tough thing for me to fix. With a family of five and no $ for a new dryer, Im going to attempt this. The front panel isnt easy to remove, I just got the door off. Will let you know how it goes. Thanks again
    Sergeant:
  • 212 Answers
You have to remove front panel. pain in **** but its not to bad once you start
Posted on Jun 22, 2009
  • 331 Answers
Also the parts service manual and parts can be bought from here if you cant find them locally. www.techray.com click on the guru guy and use the drop down menus to pick your appliance and parts.
Maytag neptune mde5500ayw chirping, buttons wont do anything. was told to replace control board. that did'nt help at all. any ideas?
The blower wheel on these tends to wallow out. That makes the dryer overheat and take twice as long to dry the clothes. Lint begins to build up in the filter housing. Finally the temp exceeds 350 and the round white fuse on the blower housing melts. Boom you has got a dead dryer. To get into the slopefront type dryer seems a bit intimidating bit really is not. Remove the door. The door is reverseable so 2 more screws opposide need to also be removed. Then the goalpost shaped front pops off. Then that reveals the top hold down straps. Remove them and top can be popped. Next you remove the front shroud the drum rides on. then get the drum out. Did I mention you do not work from the back at all on this model? Do not try to fix it in the wash room. Take it ouitside and put it on the picnic table or a tailgate to repair it. You will need a phillips head screwdrivers pliers 1/4 and 5/16 nutdriver and snapring pliers.
Shopvac to clean it up and probbaly a new fuse and blower wheel.
SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 31, 2012 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune dryer is making a scratching noise.
If the sound seems to come from the front of the drum it's probably the felt guides. The bottom one will wear first and make a grinding, rattle like sound. You can access it by removing the front panel which includes the door. It fits around the drum at the front. Here's a diagram. Some models have a two piece and some a one piece guide. Part 4 on this diagram is one. It's called a seal here. DIAGRAM
If the sound comes from the rear, there is a nylon bearing and metal socket at the rear center of the drum.
Feb 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag performa electric dyer makes dragging noise drum turns but acts like something catches and makes a dragging or scraping sound
assuming nothing is stuck around drum pull off the front and check the fan. If it is noisy for a few seconds after you stop the dryer then the fan may be stripped on motor shaft. while off you can check the front glides and the rear rollers
Nov 17, 2010 | Maytag Neptune MDE4000 Electric Dryer
Maytag MDE5500AYW 220V Electric Dryer. Makes a
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
Mar 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Electric Maytag Neptune Dryer - rattling noise
Your probably going to have to remove the rear panel and take a look to see what is causing the noise.
Disconnect the power cord and exhaust tube, remove the rear panel and check for anything loose.
You can also pop the lid and fold it back to inspect the top of the tub and belt. Roll the drum all the way around and inspect the belt for "chunks" missing.
If you include your model number, I can send you a web site that will show you an exploded view of the dryer.
Regards,
Aug 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The upper cabinet of the Maytag MCE8000AY Electric Dryer heats up, but the air isn't blowing out the vent. I can't find a filter to check or where the top cabinets vents to the outside vent. Anyone help??
You must remove the screws from the door and the hinges there are 8 screws 2on the top hinge 2 on the bottom and the other side also.After that the door lefts up and toward you.Once the door is off the panel around the door should come off then there is a shroud infront off drum remove 4 5/16 screws off then then cheak for lint obstruction or piece of clothing around the blower housing.Hope i helped:)
May 18, 2009 | Maytag Neptune MCE8000AY Electric Dryer
My maytag electric dryer squeaks when it stars up and sometimes during operation.
most common causes of a noisy dryer are bad drum support rollers, a bad idler pulley or a bad blower wheel
May 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Electric Dryer - replace belt
The belt needs to be above the metal. Otherwise the repair looks good. Easy fix. Thanks for the pic.
Oceti
Jan 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
203 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
