Question about Garden
How to put a cutting belt on a craftsman RER1000?
  • 89 Answers
Cutting or blade belts our not that bad if you follow these two things.Idler pullys that are flat ,the flat side of the belt goes against it. If the pully has a v in the pully ,the v side of the belt goes in the v most times you can figure it out as a lot of mowers out there and the decks are different
Posted on May 08, 2014
Ihave a craftsman ridding mower model #917.289900 new belt for the deck new blads it still leaves miss cut in the middle anybody know why?
usually if its missing cut it's not rotating fast enough, or the other thing it can be the blades have not been sharpened. some companies that make blades don't sharpen them so they can be handled, it will have a leading edge and you need a sharpening stone to put a cutting edge on the blade. and the blade has to be put in the right way round. flate top cutting edge bottom.
Jun 14, 2017 | Craftsman Garden
How do you replace the large belt on a Craftsman 944.609160, 16 hp, 44" cut
I coulnd not find the owners manual online, however if you can take a pic of the top of the deck I could probably tell you how to string the belt
Aug 29, 2014 | Craftsman Garden
Putting devck belt on 48 inch cut craftsman DYT 4000
V part of the belt goes in the v pulleys. If the pulley is flat the back side of the belt goes against that. You don't need a diagram.
Jul 31, 2014 | Garden
Where can i get a belt routing diagram for a craftsman RER1000??
First you will need to look under the seat and get the correct model number like 000.0000000 then go to sears.com under lawnmower parts and look up your mower which will give the parts diagram.
May 07, 2014 | Garden
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman LT2000 Blade is staying engaged all the time, just did a blade mandrel replacement, where does the spring for the blade control reattach? What would make the blades be in motion all the time?...
sounds like you may not have the right mandrels making the belt to tight and it cant be left loose enough to allow the blades to quit turning.Otherwise you didnt put the belt back on correctly if it is around the tightener pully the wrong way that to will make the belt to tight
Apr 09, 2012 | Craftsman Garden
I have a craftsman gt5000 26hp 54" deck. I removed the cutting deck cleaned and replaced blades then when i put it all together the belt wont fit. Theres a belt tensioner rod that i disengaged but...
Belts do not change length. You are doing something wrong with the routing. Maybe the tensioner goes on the other side of the belt or the belt should be routed around the other side of both the tensioner & idler.
Gary
Jul 06, 2011 | Craftsman GT 5000 26 HP54" Garden Tractor...
My Craftsman riding mower runs fine but when I try to cut thick or tall grass the blades slow down and stop cuting, I replaced the belt thinking the belt was worn only to find I still have the same...
well yep it is,,,look at the deck first to check its not tight to turn look for sezed up bearings,,,then check that the drive belt/s are tight and not flopy and slipping also it would be a good time to check the cutting blades they need to be sharp and not blunt or they strain the belts and start them slipping too also the engine wont like the extra load put on it
Jul 28, 2010 | Craftsman Garden
Craftsman 19.5hp 42 drive belt shredded
most likely the belt was put on the wrong side of the belt retainer clips on one of the two pullys. I've done the same thing more than once. Make sure on next belt there are no sharp edges touching anywhere and while engaged or not.
Oct 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to replace the drive belat on craftsman 917273280, 21hp, 48 in cut?
you remove shield from engine remove belt, remove deck from mower and remove pulley guards and install belt replace guards , reinstall deck, put belt on engine pulley replace guard
Jul 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
