Question about Poulan Garden
Polan pro pp133
Runs for about 10 min then slowly dies out its brand new hvnt even put one tank of gas threw it checked air cleaner its not even discoloured
  • 1,041 Answers
Are you saying that this is a brand new trimmer or is it new to you, used trimmer? You are describing a problem that is typical of a used trimmer.
This is a sign of a clogged gas cap. When the gas cap can't breathe, it chokes out the carburetor.
Try this: The next time you run the trimmer, and it starts to die, loosen the gas cap, it should start running again.
Jim
Posted on Jun 25, 2009
  • Jim Parker
    Jim Parker Jun 28, 2009
    Did this solution solve the problem?
    Jim
2008 cub cadet rzt 50 run for 20 min than dies while mowing put new pump on, new fuel filter, new air cleaner, new plugs. has a 22hp kawasaki engine. fuel lines clear
When it stalls out did you check the spark? I suspect the engine is losing spark due to an ignition system failure.
May 17, 2017 | Cars & Trucks
2010 F 150 oil light warning and wont accelorate
get you a gallon of marval mystry oil drain your oil and filter put a little mystry oil in your old filter rinse it out put back on and oil plug too fill with mystry oil crank truck let it run for 3 min let cool of drain put in new filter and oil if problem still accelorate and oil light still stays on you might have problems with oil pump if oil light goes out and still problems accelorating try changing fuel filter if this doesn't do the job also crack you truck up (if it is carberated carb) take air fiter off carb intake pour a little mystry oil in carb very slowly while running this helps to clean deposites due this for about little at a time you will hear motor sound like choking stop let motor catch up do this for about 3-5 min then pour mysry oil in till motor dies let set for 3 min start motor them put gas treatment (STP) in gas tank this should do the job if you have furl injestion put one cup of mystry oil in gas tank and one bottle of (STP) and atleat 6-10 gal of gas. if this doesn't do the job you may need to tale the truck to a spec.
May 27, 2014 | 2001 Ford Focus
My masport 600st lawn mower wont stay running it appears to have a blockage in the fuel line. What action do I need to take to fix problem
you have a sticking float in the carburater you will have to get a carb kit for some carb cleaner any local auto store take off cleanit then let it soak in the cleaner 3 hrs hers the big you need a air compresser to blow air threw the carb little holes and big holes put it back to gather throw out gas install new gas and sea foam injecter cleaner 2 capsfull in the full tank you should be ready togo and have more power to
Apr 19, 2014 | Garden
I own a Paulan Pro PP133, 33cc gas trimmer. The trimmer is 3 months old. The trimmer starts, idles, but when I give it throttle to exhilarate or put under load it stalls. It will restart but continues to...
If you bought it new, then you may have water in the fuel, or fuel tank if you left it n the rain. If this is not a possibility, then check out the Link to my Tip:
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
The only thing you should have to do in the Tip is step 3.& 4. if your machine is brand new.
Jim
Aug 16, 2011 | Poulan Garden
I have a Yard Machine 5.5hp 2-stage snow blower. I bought it used but I think it is a lightly used 2004+-. I use the primer bulb and it will start within 2 pulls, runs beautifully. I slowly open the...
The running time seems to indicate a plugged fuel tank vent. Try opening the cap to see if that will allow continued running. Many engines have the vent within the cap itself, while others vent from the air cleaner through a line. Ignore the fuel drip on the adjustment screw. Hope this helps!
Dec 27, 2010 | Garden
Chevy tahoe 2003 I have just put a new fuel pump on The car runs good but after 30 min or so it slowly die when it starts to slow down I try pushing on the gas paddle and it does nothing
if you release throttle slowly does spead pick up poss plugg exhaust conv, plugged air cleaner, plugged fuel filter, most likely exhaust
Aug 30, 2009 | Chevrolet Tahoe Cars & Trucks
88 Toyota Corolla backfires through carburetor.
If that is carbureted, and has a mechanical fuel pump, try running a length of fuel line from inlet side of pump to a gas can that has fresh, clean fuel, and if it runs good that way, you know problem is most likely in the tank. Removing the tank & cleaning it out is best solution from there. I'd even be tempted to add a small bottle or 2 of Lucas Fuel Sytem Cleaner to first fill in clean tank, just to help clean lines as well as carb.
May 20, 2009 | 1994 Toyota Corolla
Engine Dies
check vent line from tank to fuel filter or canister or gas line , get air compresser and blow both lines out towards gas tank having one personstand by tank with gas cap off listening for thump sound or gushing air
Jul 13, 2008 | 1987 Dodge Ram 50
Garden Logo
251 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
