Question about Brother MFC 240C All-In-One InkJet Printer
Can't align my printer - Brother MFC 240C All-In-One InkJet Printer
    Sergeant:
  • Brother Expert
  • 316 Answers
The MFC240 is getting on a bit in age, so it is entirely possible that the waste ink chamber and purge counter are at their limit ( aka error 46). Look for a waste ink reset instruction and/or u-tube clip showing how to remove and clean out the waste chamber and instructions to reset the purge counter. There are many out there. You may want to balance the cost of replacing the machine against the hassle of disassembling and cleaning it.
Posted on May 12, 2014
Stop continual printer printer alignment hp 8500
If the Printer is printing alignment sheet, You need to re-align the printer one more time.
1.Press the Setup Button
2. Scroll to Tools
3. Choose clean Printhead
4. Let go through the process.
5. After the printer has printed alignment sheet, Turn off the printer and turn on.
If the issue still persist, Change the cartridges which are low on ink and the printer will re-align itself.
Regards,
Suhail
Oct 08, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
How do i align my printhead on canon iP1200
I assume you are using windows.
  1. Go to START, SETTINGS, PRINTERS, double click on the printer icon. Go to FILE, to PROPERTIES, then click on the printer SERVICES tab. Click on ALIGN the print cartridge button and follow instructions on the screen. hope this works
  2. Align the print cartridges Typically, you only align print cartridges after installing or replacing a cartridge. However, you may also need to align cartridges when:
    • Characters are improperly formed or are misaligned at the left margin.
    • Vertical, straight lines are wavy.
    From your printer:
    1. Load plain paper.
    2. Press the Menu button, and scroll to Align Cartridges.
    3. Press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
    From your computer:
    2. Open the Canon Pixma IP 1200 Utility.
    3. From the Cartridges tab, click Align Cartridges... . The Cartridge Alignment dialog appears. alignprintcartridgesa.jpg alignmentpanther.jpg
    4. Click Continue to print the alignment page.
    5. On the Alignment Status dialog, click OK if automatic alignment is successful. If automatic alignment is not successful, clicking OK will return you to Utility Main Window.
Apr 20, 2011 | Canon PIXMA iP1200 Photo Printer
I changed the ink cartrige,it keeps saying alignment cancelled and the copy button keeps flashing - when i open it up the ink cartrige wont slide back out it seems stuck.
The printer needs to be aligned and it wasn't done after changing the catridge so it does not want to continue. Have you tried pushing the flashing copy button to print another alignment page? Do you know how to align the printer?
After changing a cartridge the printer wants to print an alignment page to make sure that it prints correctly. Some printers have you print a page and they auto align themselves. Others cue you to print the alignment page which has a picture or other graphics that are in specific places and then it instructs you to insert the alignment page face down and press "ok". The printer scans the alignment page and configures the print heads to set up by the marks. It uses the alignment page as a map of where the print should be on the paper.
Try unplugging the printer from the power supply and wait about 30 seconds. Then plug it back in and turn it on. The display should say "print alignment page". Choose yes or confirm to continue. Your printer will either print the page and align itself, or print the page and tell you to insert it and continue. Either way follow the prompts and complete the alignment process in order to continue printing as normal.
If you are unable to get the printer to reset and start the alignment procedure over again, please advise and I will help you solve this problem.
Nov 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
HP C4180 keeps telling me cartidge alignment failed,why is this
hpweb_1-2_plus.gifhpweb_1-2_minus.gifMethod one: Align the printer with Solution Center
  1. Load unused white paper (if needed).
  2. In HP Solution Center , click Settings , and then click Printer Toolbox .
  3. Select the Services tab, and then click Align Printheads . Figure 10: Align Printheadsc01950052.jpg The Align Printheads window opens.
  4. Click Align . The printer prints the alignment page.
hpweb_1-2_plus.gifhpweb_1-2_minus.gifMethod two: Align the printer from the control panel
Oct 26, 2010 | HP Photosmart C4180 All-In-One InkJet...
Printer head alignment is not aligned from A to F.
go to "printer and faxes",then right click on the printer ip 1800 and go to the 'properties'.....then click on "clean head".......
do it many times until the head alignment is ok...
Jan 07, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Printer will not print or make copies. Our alignment page got accidently thrown away. Can we align the printer without it? Can we get a new alignment page?
alignment page is done during the installation of new ink cartridges. you could re align the printer.
press setup > tools - ok > align cartridges - ok and then scan the aligned print out
Oct 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
Every time I change a cartridge in my HPC4280 printer, a window pops up on my monitor and says I need to do an alignment. Fine, but even though I tell it I already have an alignment sheet, it prints...
I believe that you are not completing the alignment process.
Let me explain the alignment process..
1- Remove the usb cable from printer and computer if connected through usb cable.
2- Turn off the printer, wait for 30 seconds, turn on the printer
3- It will print an alignment page
4- Place this page on scanner glass of printer from right hand corner
5- Press OK or SCAN button on printer
6- This will complete the alignment process.
It will not print an alignment page again and again.
Regards
Harpreet_351
Oct 11, 2009 | HP Digital Printers - Hewlett-Packard...
I'm missing the HP Alignment page for an officejet J3680
when you do the alignment procedure, your printer prints the page to place on the scanner glass and complete the alignment. A page from another printer will not align your printer correctly. Select tools in the menu and then select printer alignment, the instructions are printed on that alignment page.
Jun 24, 2009 | HP PSC 2410 All-In-One InkJet Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
ALIGN HP 1510 printer
1Verify that the printer is turned on. If the printer is not on, check to ensure the power cord is securely plugged into a working electrical outlet, then press and release the power button one time. Wait for a few seconds while the printer powers up. Step2Lift the paper output tray. Load the letter or A4 unused plain white printer paper into the paper input tray. Lower the paper output tray. Step3Double left click the "HP Solution Center" icon to open the application. Single left click the "Help and Support" tab. Single left click the "Printer Toolbox" link. Single left click the "Align Print Cartridges" option to open the "Alignment Page" window. Single left click "Align." Step4Wait while the printer prints an alignment page. Examine the alignment page carefully and select the option that appears to be most correctly aligned. Select that option by single left clicking the corresponding option on the drop-down choices in the alignment window. Step5Single left click the "Done" button once you have entered all appropriate options. Wait while the printer prints a confirmation page. hope this helps
Jan 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
61 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
