Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony su 50sx red light flashing 7 times - Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
    Master:
  • Sony Master
  • 688 Answers
This may be your lamp fan not spinning. Sometimes you can get it to operate temporarily by cleaning the dust from it & spin the blade by hand to get it started
Posted on May 09, 2014
techman
  • 3130 Answers
SOURCE: Flashing red light
Joechillin, how much TV repair experience do you have and do you own a mutimeter as well as an osilliscope? Ok first thing your going to need to do is to get a schemtic diagram. Find out with the scope, if the horizontal drive pulse is there when you turn on the set. If it is not then go back to the SMPS and check that. If it is, check the drive all the way up to the horizontal output transistor. If it is good up to there, and still no sweep power supply? Your going to most likly need to replace the flyback transformer and the horizontal output transistor and go from there. If you are there with this, great. But really man if you have no TV repair experience, we cannot teach you how to, as there are alot of factors involved. There is also alot of High Voltage inside these sets when the plug is even out of the wall. Also everything inside these sets is mounted or soldered on a printed circuit board. This set is a solid state TV and there are NO user replaceable parts inside. My friend, I would Highly recommend that you call in a trained service person to assist you with this repair. Good Luck
Posted on Oct 08, 2006
SOURCE: sony tv red flashes
LED flashes of 8 times are indicative of a "High Voltage Error" which means something along the lines of "T8005 is faulty. (D board)" according to the service manual. Most likely it will need a professional to look at it. A link to the service manual is here: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Jul 02, 2007
rulds2008
  • 3866 Answers
SOURCE: My sony tv Comes on some times but then some times does not
On most of your rear projections you got GUNS and if there out of allignment or overheat you will get this error and it will need to be serviced.
Posted on Apr 22, 2009
SOURCE: tv will not turn on
Change the bulb
Posted on Sep 08, 2009
  • 497 Answers
SOURCE: sony kdsr50xrb standby light red 3 times
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
NOTE: You may have to replace the lamp also if the issue persists.
Check this Link for more information.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C461251
Good Luck!!!!!!!!!!!!!!!!!!
Posted on Sep 16, 2009
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
I have a tv Sony Trinitron XBR. It does not turn on; the LED red light blinks 7 times.
Common problem on those. It has deflection stopped. I.C. on deflection board. Need shop to repair.
Nov 23, 2014 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
15 months into owning our Panasonic TC P46S1 (3 months past warranty), the screen has gone black. The red light on the front flashes 7 times with a pause of 3 sec and then repeats. I have heard horror...
My suggestion is that you get an estimat from a dealer on repair costs and you decide whether you want to spen money on a part or new set. This is a bad circuit board and probably the power supply. The repair will be around $200.00 minimum unless you get lucky and there is no major issues and the board can be repaired.
The service manual says. you have what you call a "shut down circut" it is for safety and when one of the internal boards gets shorted or is not working properly, service doc reads as follows
7 Blinks SOS:
Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times
thiera blinking 7 times is cuase by a fualt in sc,su,sd board.
If the board shorted another before it went dead you could have other issues, thats why you need a tech to look at it and give you an estimate. You never know, this being so close to warranty they might work with you on it.
Mar 23, 2011 | Panasonic TC-P46S1 TV
Picture went out and no audio, red light on power blinks seven times and repeats.
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Just bought panasonic th-42x20k, when turn on hear a clicking sound and then turn off, red light under screen flashing 7 times
Red light flashing indicates that "SC voltage is floating". I'd recommend replacing the SC, SD and SU boards. Also know as the Y sustain (SC), Upper and lower buffer boards (SD, SU).
I suggest you contact your local Panasonic Service Agent as parts are only available from Panasonic and are quite expensive.
Jan 18, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Power light flashing
if flashing 7 time need replaced sd board and su and sd board
Panasonic TXNSD1RJTU SD BOARD BOARD, SD (Y SCAN DRIVE LOWER ASSY)
Panasonic TXNSU1RJTU SU BOARD BOARD, SU (Y SCAN OUT UPPER) ASSY
Panasonic TXNSC1RJTUS SC BOARD BOARD, Y SUS DRIVE BOARD
Jun 03, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
