Question about Datacard Group SP75 Color Card Printer
Lamination module not detecting in datacard sp75
3 Suggested Answers
  • 39 Answers
SOURCE: Air bubbles in laminate
Do you have a dual lamination station in your printer? How old is the printer?
There may be contaminates on heated platen that is causing the bubbles. I would go into the printer settings and try various settings such as LAM1-BOTH SIDES and LAM2-NONE then LAM1-NONE LAM2-BOTH SIDES to isolate the issue
Posted on Aug 19, 2009
prashanthcl
  • 460 Answers
SOURCE: will datacard sp75 plus and sp75 run in the same
same driver will work
Posted on Aug 20, 2009
Testimonial: "THANKS DUDE"
HOW DO I DISASSEMBLE TO CHANGE LAMINATE POWER BOARD
try utube or go to manufacture website for instructions.
Dec 05, 2014 | Datacard SP75 Plus Color Card Printer (P/N...
Lamination Problem
You have to go to printer driver, see the general settings and put more darkness(normally it ranges from 0-20, it should be set at 10. Try puting the darkness at 11,12,13, etc until it laminates properly. Don't forget to put back the setting when printing ymcko, or you will burn ribbon.
If the head that prints color is the same that laminates, then you should be cleaning the head after use.
Jan 17, 2014 | Datacard SP75 Plus Card Printer
Password advanced user diagnostic print tool datacard sp75
The advanced user password for the SP75 Plus diagnostics is 926918
Jul 09, 2012 | Datacard SP75 Plus Card Printer
Error op-01619 lam comm error
In order of likeliness
1. Bad power supply in the printer, in the printer there are 2 power supply's if you have 1 lamination module 3 power supplys if you have 2. 1 power supply may have failed and need to be replaced. You will need to remove the outer covers check for the green light on the power supply. Then check the voltage with a volt meter.
2. Faulty system board. Try a firmware update.
3. If the printer was dropped or bumped hard it could be a loose cable inside.
If all that fails, I would take it in for service.
TulsaBiz.net
or MidWestIdSolutions.com
Jun 03, 2011 | Datacard Group SP75 Color Card Printer
My datacard printer ribbon is supposed to get upto 500 images, but it is skipping every other color series so I am only getting 250 images
Every time you open the printer, it advances CMYK panel 01 to position the print head.This can cause loss of ribbon. Avoid opening the printer to the maximum you canoptimize your prints.
Jan 20, 2011 | Datacard Group Datacard SP75 Color Card...
Running "test" cards on the SP75 Plus.
Is the test card meant to the laminator heated?
If so, you should be able to set the laminator time out from 30 minutes to 5 hours.
This is done through the front panel under the configuration menu.
Hope this helps
Apr 27, 2009 | Datacard Group SP75 Color Card Printer
Feb 11, 2009 | Datacard Group SP75 Color Card Printer
Heater error in Sp75
Sounds like either the thermocouple or the heater went out. Was this the error code?
OP-01604 Thermocouple problem in L1 laminator
The comments in the service manual states:
- Check the thermocouple wire for damage.
- If the thermocouple was recently replaced, verify that it is not installed backwards
- Verify that the thermocouple connector is not unplugged or plugged in backwards
I would probably order a replacement part, call in your local DataCard service representitive or send it to DataCard for repair.
Oct 01, 2008 | Datacard Group SP75 Color Card Printer
Uper Duplex not holding card in place
early model sp75s have that type of problem. It can normally be fixed by replacing the clutch and duplex board. Very easy to replace. Be sure to be aware of the clutch spring when removing the duplex tray. Use the lower duplex assembly as a guide.
Jul 02, 2008 | Datacard Group SP75 Color Card Printer
Datacard Group SP75 Color Card Printer Logo
44 people viewed this question
Top Datacard Group Office Equipment & Supplies Experts
Jaime Hernandez
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
