Question about OKI C3530N Color MFP Printer
How do I reset error code 980 on oki c3530 - OKI C3530N Color MFP Printer
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: OKIDATA C3530 MFP with 980
buy a new fuser
Posted on Oct 07, 2008
SOURCE: does anyone know what is
If you look on top of the fuser roller(upper orange roller), there is a thermistor (orange rectangle plastic that rides on the roller) you will see four wires going into that housing. Two are for the thermistor and the other two is for the fuse that is built into the housing. You would have to use a soldering iron to melt the plastic that the fuse is sitting in. You would have to figure out what to use as a fast blow fuse.
Okidata makes it difficult to take out the thermistor because the nut is locktite on the screw. Try using the soldering iron to melt it. Just make sure you dont damage the thermistor.
Posted on Jul 03, 2009
  • 73 Answers
SOURCE: How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Posted on Oct 07, 2009
Testimonial: "Great fast response."
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
Oki c710 error 980 reset
Per the technical manual - Media wrapped around the fuser error. Turn off the power. Replace the fuser....
It is possible to unravel the paper from the fuser.
Feb 15, 2014 | Oki Electric Industry OKI C710dn - - color...
How do I reset fatal error code 980 on a oki c5650
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
Jun 18, 2011 | OKI C5650n LED Laser Printer
I had a piece of paper wrap around the fuser of my Oki C5650 printer. I have removed the paper (all of it.), but now it is displaying a 980 Fatal Error code. What do I do now?
I just had a service call with a 980 error. i removed the paper wrapped around the fuser roller but the error persisted. The only thing that cleared the error was to replace the fuser. I am not sure why but the fuser was shot after it had the paper wrap inside it.
There is no reset to clear the error. The only fix was to replace the fuser.
Aug 18, 2010 | Office Equipment & Supplies
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
980-fatal-error
Service call 980:Error
Cause: Error by media clinging to the fuser
Error description: Media has clung to the fuser.
Solution: Power OFF. Replace the fuser unit.
Nov 19, 2008 | OKI C5800Ldn Led Printer
hola
quiem puede ayudarme a desifar el error 980 de ld oki c6100
gracias
Apr 09, 2008 | OKI Office Equipment & Supplies
OKI C3530N Color MFP Printer Logo
44 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
