Question about Exercise & Fitness
Hca healthstream I have a model dk 380 health stream treadmill. After walking on the treadmill for about 10mins it starts to smell of rubber burning. Had it looked at and was told that the treadmill in goos working order and the problem may be that I need to change the operation from overweight mode to normalweight. How do I do this. Anna
fishdoctorfi
  • 178 Answers
SOURCE: bad burning smell and turn off when i'm walking on it
Sounds like the BELT tensioner........
Posted on Mar 11, 2010
bwinton
  • 83 Answers
SOURCE: Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: My nordic track treadmill's walking belt stops
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
Posted on May 18, 2010
rowdy05
SOURCE: I am getting an E7 error code on the LED screen. I
hi was wanting to no how much to replace speed sensor on treadmill thanks on,{ model hs1175t hornet 2006}
Posted on May 25, 2010
SOURCE: Prosoft Plus Pro-Form 500i treadmill
i push the buttons 6,7,8,9, and the incline up works but all the other buttons dont not even the start button,plz help,,,,,aaaaa, :(
Posted on Aug 07, 2011
My Horizon T80 treadmill is emitting a smell after operating a while not an electric smell but a rubber chemical smell
How old is the walking belt? When was it last replaced? How many miles are on the belt. Seem like your belt and deck is worn.
Jan 01, 2014 | Horizon T92 - Treadmill
Healthstream manual I have a GE3400T healthstream
go please to www.fitness.manualsonline.com or www. retrevo.com
and download for free.
God bless you
Oct 31, 2013 | Exercise & Fitness
Smell like something is burning
It means ur Belt is starting to rip and it It is probably getting tangled
up in the motor so it burns and smells or something is in the tredmill like a blastic bag or something so I would look at that
Aug 29, 2013 | Weslo Cadence 450 Treadmill Walking Belt
I have a proform 8.5 that when walk on smell like rubber burning
Dear Sir:
Thank you by your request, I will help you right now.
BURNING SMELL If you can walk on your treadmill but you get a burning smell from it,you have a bad problem and discontinue use immediately and unplug the treadmill. Burning smells are most commonly associated with the following problems: 1) Very high belt/deck friction. 2) Short in the motor. 3) Short in the wiring or electronics. 4) Literally cooking the lacquer or cardboard core (on cheap machines)in the motor from belt friction or a drive system obstruction. Friction is the #1 cause of this problem. Many cheaper treadmills have amotor with a cardboard core (people wonder why we are so down on cheap treadmills) and if the voltage and amperage through themotor heats it up sufficiently, it begins to smolder. If this is the case, you normally have to replace the belt and the motor and inspectthe deck. If the armature has cooked enough in the motor, you also have to replace the motor. If the belt and deck check out OK, check for a short in the motor. Youcan run the motor with an independent power source like a fullycharged cordless drill battery to see if the symptoms are the same. Click on thefollowing link for our motor test. If the belt and deck check out and the motor is OK, then check yourwiring and electronics for signs of scorching and replace the appropriate part(s).
Thank you in advance, sincerely. God Bless you.
Iif you need further assistance, please contact me.
E.CUADRA
MANAGUA, NICARAGUA C.A.
Sep 29, 2011 | ProForm 80 ZT Treadmill
HOW DO i START MY PROMFORM 380 TREDMILL
You need to insert the safety key without it, it is not going to work
Jun 08, 2010 | Proform 380 Treadmill Walking Belt
I have a Proform 380 Treadmill. When the treadmill is on the belt rubs on the left side.How do I center the belt?
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
May 24, 2010 | Proform 380 CS Treadmill !
Exercise & Fitness Logo
121 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
