Question about Sony KF 50SX200U Compatible TV Lamp
Sony 50sx200u red light flashes 3 times then atemps to light up then goes off fan seems ok#
    Scholar:
  • 195 Answers
Try a new bulb. Sony XL-2000, or if you can replace the old one from the housing (simple to do), an E23H 120 Watt will work.
Posted on May 08, 2014
My sony wont turn on the red light keeps flashing
Need to check all your switches and connections.
The Red led indicated and device function problem and you need to respond with the sequence of flashes. ( Example 1 long and two short. or Flashes 3 times ? )
Let me know if the fan is running and the age of the power supply.
May 07, 2014 | Sony KF 50SX200U Compatible TV Lamp
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
I have a Sony tv KDF50WE655, the other day while I was watching tv, heard a noise and the tv went off, displying the lamp red light..I ordered and replaced the lamp. I made sure the lamp is ok and the door...
Please make sure lamp cover is fixed properly in its position after lamp replacement as it has to press a safety switch located nearby lamp cover.
3 times red blink problem is related with that lamp cover safety switch only.
Hope this will help.
Thanks.
May 27, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have KDS-50A2000 Sony SXRD Projection TV. Serial #9028985. It was working fine then a few days ago I went to turn it on and the red power light was blinking 4 times and repeat... I then opened the lamp...
hello, this can cause the red power light to flash 3 time also if the lamp cover is not fitted securely this can also cause the light to flash 3 times 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped hope it helps
regards
shaun
Jan 03, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Red light on front flashes 4 times and picture comes on for 1 second then goes dark and red light flashes
THE FOUR BLINKING RED LIGHTS INDICATE A FAN PROBLEM. CHECK IN THE BACK AND MAKE SURE THE FANS ARE SPINNING ON POWER UP.THE PROBABLE CAUSE IS THE LARGE LAMP FAN LOCATED ON THE LOWER LEFT WHEN LOOKING AT THE BACK OF THE TV
Dec 15, 2009 | Sony KDS-R50XBR1 50" HDTV
As flashing red light
Flashing red light indicates a hard ware problem.
In MOST cases it's a problem with the PS3 motherboard. You can try booting without the hard drive inside, but it's rarely the cause.
Time to call Sony. 1-800-345-SONY
Nov 20, 2009 | Sony Playstation 3 (PS3) Console
TV won't come on. Standby goes green,then goes red blinks 3 times
3 flashes means the lamp door is not on correctly or the lamp door switch is broken.
Apr 08, 2009 | Sony Grand WEGA KF-50WE620 Television
Red flashing light and PS3 won't work
I have had this same probelm unfortnaully .. It sux , and after trying alot of different things and reading , and talking to sony themselfs seems only fix is $150 repair or a new playstation :( . . Have you noticed your fan is just loud and has like 3 stages of loudness? Thats what mine did , and i got the red flashing lights if not loud then anthor device in your playstation has stopped working sorry to say
Feb 02, 2009 | Sony Playstation 3 (PS3) Console
Sony KDF-55WF655 Won't Pwr up
There's a fan in the optical block (light engine) You may also have either an intermittent fan or a bad connection from the fan(s)
michtech
Jan 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KF 50SX200U Compatible TV Lamp Logo
22 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
