Question about Samsung Refrigerators
My Samsung silver nano freezer not cooling - Samsung Refrigerators
  • Samsung Master
  • 5,323 Answers
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
Posted on Apr 10, 2015
2 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: samsung silver nano
Friend,
ngfam1 At your service!
How old is the refrigerator?
If ice forms you may have an outside air leak passing the rubber seal around the door. usually at the corners!
If the seal is not perfect you may not be able to see it with your eye to realize it is leaking air!
my advice is,
if the refrigerator is 9 years old or more it is cheaper to buy a new one!
Todays refrigerators are much more efficient and cost a hell of a lot less to operate. your electric bill will go down Too!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
Silver nano
Refrigerant leak if the compressor is running. Not a homeowner repair. Required EPA license to repair.
May 07, 2014 | Samsung Refrigerators
Motor constantly running stops when door of either fridge or freezer is opened but starts again when door is closed - Samsung Silver Nano
It's possible that your fridge has a fan to cool down faster your food and to prevent frost. It stops when you open the door to to avoid losing the cold.
Il you send me the exact model (for example RS7568THCSP/WS) I can add a more precise explanation.
Sep 12, 2013 | Samsung Refrigerators
Dear Help 'Desk, I have a Samsung silver nano fridge/freezer. I've broken one of the removable door shelves in the freezer. Can you suggest a suitable (preferably clear) glue to repair the
Fevi-quick stick fast glue will be useful.It will take few minutes to hold the broken parts.Dont put overload of food stuff on the rejoined tray.But it will hold the basic load.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Compressor and fan working but it is not cooling
If everything is fine, check whether the door is closed properly. There may be some vent while closing the door.
Oct 29, 2012 | Refrigerators
Freezer is fine but the main fridge is not cooling model is an siler nano sr447nts
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 17, 2011 | Samsung Refrigerators
Hi i am having samsung fridge cooltsech plus silver nano i have a prob;em in my fridge that in winter the cooling in the refrigerator is very sytrong i have increased the temperatire to 7 degress which is...
If your veg is freezing you need to RAISE the temp in the fridge,if #7 is coldest,then #1 is warmest.SET IT TO #3.You should keep a fridge at +5C for best storage of CHILLED food.you should also adjust your fridge for summer and winter ambient temperatures.a fridge/FREEZER thermometer is ESSENTIAL.OTHERWISE YOUR WASTING MONEY/ENERGY.
Nov 12, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung silver nano freezer fan blades broken due to ice build up. need new blades. Please tell me where can I get Them. And how to stop it happening again.
Samsung silver nano 5yrs old - trips main electrics - 13A fuse ok but everything trips when the fridge/freezer is switched on
Aug 14, 2010 | Samsung Refrigerators
I have a samsung silver nano...the indoor unit & the outdoor unit fans are running...but there is absolutely no cooling. Any idea why?
  • Ensure Air Filter is clean - clean as necessary
  • Ensure Evaporator coil is clean - clean as necessary
  • Ensure Condensor coil is clean - clean as necessary
  • Inspect all wiring inside the unit for any loose or damaged connections - correct as necessary
There could be a failed compressor relay, run capacitor, or compressor motor/valves. Of course, it could also have lost it's refrigerant charge.
Without being onsite with toolbox in hand, I hope you find this information to be very helpful moving forward. :-)
May 10, 2010 | Samsung AW0503B Air Conditioner
Samsung silver nano
Friend,
my advice is,
A&E Factory Service
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 31, 2008 | Refrigerators
Refrigerators Logo
79 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
