Question about Honda GCV160 5.5HP 2300PSI GAS-POWERED POWER WASHER
How do I add soap/chemicals in my Honda GC 160 pressure washer?
Other hand scrubbing separately with a brush, is there not a way to incorporate the soap into the machine to spray out of the wand? I have not used it in years and it seems like there was a way but I cannot figure it out. Thanks.
3 Suggested Answers
  • 18 Answers
SOURCE: wont pull detergent
problem is that u have to use with lowest pressure i believe black tip
Posted on Jun 27, 2009
  • 760 Answers
SOURCE: My honda gc 160 pressure washer i have to take the
With the tip removed you have pressure? or you have flow. Usually, with no tip you have very little pressure with lotsa flow. Sounds like tip clogged up. Have you tried other tips? If you hold the tip up to the light you should be able to see through the oriface.
Posted on Jul 18, 2010
Tip
Greasy hands cleanup / REALLY CLEAN HANDS
If you use strong hand cleaners and scrub brushes you can avoid both.
Soap will attach itself strongly to grease IF it is given a chance.
Typically people first wet their hands with water then add soap.
The water acts as a barrier to the soap to some degree.
Use any liquid dish soap. You only need a few CCs (cubic centimeters).
Apply the liquid soap to the palm of one hand and then rub your hands together
to spread the soap somewhat evenly. Then use your fingertips to work the soap into the grease for about 10 - 30 seconds per hand. The soap has now chemically bonded with the grease. Place your hands under running water while using a sponge with soft nylon mesh (usually white, not green) to remove the soap. The water will now bond to another part of the soap/dirt molecules and pull them off your hands with the help of the mesh.
This concept can be applied to bathing your body. A little soap, a lot of rub.
Frank in NC
on Oct 27, 2013 | Esca Tech Incorporated D-Lead D-Wipe...
How do you replace the honda gc190 decompression mechanism
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily. The valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Mar 16, 2013 | Karcher 2500 PSI Pressure Washer
Chemical wont siphon
In most cases this is because you have a high pressure tip, the red, white, yellow or green tip, on the wand. The detergent system will only work if you have the black, soap tip on the wand. With a pressure tip on the wand, there is too much back pressure for the syphon system to work. If you are using the soap tip, check the feed tube for the detergent for blockage, especially at the pickup filter and where it attaches to the water line.
Sep 16, 2012 | Powerboss 020309 3000 psi 2.5...
Honda GC190 can't pull starter cord
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily then the valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Aug 29, 2012 | Honda Garden
Troy bilt 2600 psi when you turn the water on it shoots out through the chemical supply inlet
My chemical supply inlet has a checkball and a spring that keeps pressure in check. There must be debris behind checkball. Easy to check by removing the fitting. If faulty and parts not available, plug fitting and add an aftermarket injector from www.pwmall.com. that you can install when you need it. Good luck
Sep 30, 2011 | Honda Black Max 2600 PSI Pressure Washer
I was able to use soap all last season, this year, i cannot get it to come thru, i know all about the low pressure deal, it seems to be clogged/ is there any way to specifically clean it where it enters...
Soap injectors are easily clogged or will not work because of design (air leaks will prevent chem from entering if chemical has to be drawn uphill) . They work with siphon action and will only work with very little pressure at the tip but good volume. If your siphon valve has the ball in place, however is missing the fine spring that holds the ball against seat (fine spring holds ball aginst intake fitting), the soap will not be sucked into stream. If ball and spring are in place, try elevating the soap container higher than the opening of the port (gravity feed may help to feed soap into system) . May be better to use an aftermarket downstream injector valve sold on ebay or many outlets. Cost about $20 but work better and are adjustable to save on soap. Search ebay for "Chemical Injector For Pressure Washers" or google "Pressure Washer Downstream Chemical Injectors" Various prices but lower price units work better than factory. Good luck
Jul 18, 2011 | Honda Black Max 2600 PSI Pressure Washer
My pressure washer inlet tube does not syphon chemicals. The hose is fine and the strainer is new. Do I have to do anything to the pump body to make it work? It is a 2750psi Honda
you have downstream injection and this means only with low pressure will **** chemical you need a soap nozzle or check your injector make sure is in the right direccion
Aug 24, 2010 | Honda Maxus Prosumer MX5223 Pressure...
I have a GX Honda 160 5.5 and cant get the soap suds to work
Are you using a soap nozzel? If not the soap injector will not work.
Jan 25, 2010 | Simpson WB4200 Water Blaster 4200 Psi Cold...
Wont pull detergent
Jun 20, 2009 | Honda Maxus Pressure Washer MX5222
Honda GCV160 5.5HP 2300PSI GAS-POWERED POWER WASHER Logo
42 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
