Question about Winegard RV7042 Wallplate/power Supply Model RV-7042
Should I buy a new antenna wallplate for my rv? Current wallplate does not have an on/off switch mentioned by some bloggers. I wish to improve my reception.
I am not getting good TV reception in my RV. I've done some research and bloggers suggest I turn on the wallplate switch near the coax cable in order to improve the air signal. My wallplate does not have this switch and I have looked in nearby cupboards. I am going to replace the antenna head, but need to know if I should buy a new wallplate with an on/off switch. I don't know it it's necessary since the orignal one did not have it.
    Top Expert:
  • 3,698 Answers
Some HD antennas , in RV have a signal booster which enhances the signal . these may be the ones with the on and off switch. These run off either 12 or 120 volts. If replacing the head/ antenna buy one with a signal booster. It usually come with it's own switch or buy one for it at radio shack.
Posted on May 07, 2014
I have a sanyo tv that worked fine on sat at home now in my rv. changed to air antenna and channel scan only shows rv channels the returns to need to scan screen
Check and replace the main system control memory IC. It is faulty. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 24, 2016 | Sanyo Televison & Video
Tip
Improve Blogger PageRank by optimizing post page title
As each post is having its own title , chances are there for the results to be in top pages.Now we can do this by performing a simple edit on blogger template
Open edit HTML section
Now press Ctrl+F and search for
<title><data:blog.pagetitle/></title>
Replace that code with the code in the following box and save your template.
<b:if cond= 'data:blog.pageType == &quot;index&quot;'><title><data:blog.title/></title><b:else/><title><data:blog.pageName/></title></b:if>
Well it does not mean that this trick will improve blogger PageRank to a great level . It depends on quality of your backlinks, content and many other factors.
on Nov 09, 2010 | Computers & Internet
Tip
How to give your google blogger weblog a custom domain CNAME
This is quite a simple process you can either use a domain name that you have already registered OR create a new domain name for $10 (£8) using the google apps powered by www.godaddy.com
USING THE BLOGGER WIZARD:
If you wish to go with the default option that is provided with the blogger wizard it will create your domain on the godaddy hosting servers you can still access and edit your weblog through your blogger dashboard this is also where you setup the new domain name in the publishing tab.
First you will need to check the availability of your chosen host name on DNS you only use one of these the top-level servers
  • com
  • net
  • org
  • info
  • biz
In this case I wish to change my weblog hostname now held at www.blogger.com which is www.fixyatipsandtricks.weblog.com to my desired URL I also own www.windowstipsclub.co.uk jump to the setup webforwarding heading of this tip for help on how to do this.
http://www.windowstipsclub.com
  • Top-level domain name: .com
  • Second-level domain name: windowstipsclub.com
  • Host name: www.windowstipsclub.com
You need to either buy the domain name @ godaddy.com first OR use the easiest option and have the blogger dashboard create it for you in the settings publishing tab. Where you need to check the name availability on the DNS servers
All you need to do is attach a method or payment to your google account and follow the wizard until you see following page that will tell you that your blog is ready!
NOTE: that you can switch back to blogspot.com at any time which will still be free see the link at the top of this screendump. It also tells you that web-forwarding will also be set up for you and users who search using the old blogspot URL will be automatically directed to the new domain name.
Its is an annual renewal contract that can be set to automatically charge your credit card that you have attached to google and is linked into your google account that you will already have linked to blogger click this image to manage this.
REMEMBER : this is not the same as just changing you weblog name on the blogger servers check this google support LINK where your links will be lost.You will in effect be hosting your weblog on the godaddy server and all your previous links will be automatically forwarded.
NOTE: it may take upto 3 days for the link to propagate through the internet domain name servers (DNS) as shown below
SETTING UP WEB-FORWARDING:
Web forwarding is a way for your domain to be pointed to another web address or page. You can choose to have your domain name remain in the address bar, which is called “framed web forwarding". Alternatively, you can choose to display the new address, which is known as “non-framed web forwarding”.
For Example if you own www.windowstipsclub.co.uk and also www.windowstipsclub.com and they are registered at different hosting websites then you can set up web-forwarding on the first server to point to the domain where the full website is.
Many companies do this that register the same website name on all the domains if you also own www.windowstipsclub.net this can also be setup to forward to your dot COM of the same name it is a good idea however to host all the addresses at the same host you may get discounts
You can access this on your weblog through the settings + publishing tab and select either the google apps OR your own custom domain name you will have to logon to the company that you used and change some of the DNS settings to do this correctly.
SETTING UP A WEBSITE CNAME:
Basically this is an alias name for your website his helps when running multiple services (like an FTP and a webserver; each running on different ports) from a single IP address this is the number that your ISP will give you and is unique for all websites.
Each service that you will run can then have its own entry in DNS
  • www.windowstipsclub.com
  • ftp.windowstipsclub.com
  • info.windowstipsclub.com
Check out these two support links for help on how to do this first look at this youtube tutorial that shows how to add the IP address for the new servcie and CNAME that you want to add to your existing IP address.
For a range of hosting website instructions visit this blogger help page it gives specifics for 5 of the most popular companies.
FOR MORE TIPS OR THE SAME OR INTERESTED IN EXPANDING YOUR EXISITING HUNGER FOR KNOWLEDGE
You might also like to remove your weblog navigation bar from your new site check out my TIP here on how best to do this for all my blogger tips @ FixYa check out my new Windows Tips Club weblog click on the logo
Also check out may facebook page that is also on the facebook NetworkedBlogs application
SpideRaY
on Jul 03, 2010 | Google AdWords
I installed a coby tv in my RV. Auto scan worked great for a year. Today it picks up no channels at all. Everyone else in RV park has 20+ channels. The scan performs everytime, but picks up nothing
If you've tried all positions with antennae, booster switch is on, and are sure you have all settings on TV correct, try running an alternate cable directly from antennae head to back of current plate where your co-ax from antennae is attached. That will tell you if you have a bad cable or connection from antennae to plate inside. Just get a piece long enough to go through door or window to current spot where connected. If that doesn't cure it, then it's a head or booster switch problem. You can even by-pass the booster and go direct to TV to see if any better.
Sep 03, 2011 | Coby TFTV3227 32 in. LCD TV
There is a wallplate with 2 outlets and 2 switches that control 2 separate lights. while trying to install new switches and outlets, wires came loose and now I have no idea what is what.
Open following link to see illustration:
http://waterheatertimer.org/images/Single-pole-switches-in-4-gang.jpg
Each residential electric box has 1 hot wire. This wire should be black.
Hot wire carries power from the breaker box.
Use tester and find hot wire.
Each device in box connects to the black hot wire using short jumper wires.
Outlets: Hot wire connects to brass colored screw.
Single-pole switches: Hot wire connects to either brass-colored screw.
Neutral wires are usually white, and are twisted together.
Neutral wires connect directly to silver screw on each outlet.
Wire going to lights connects to other brass screw on each switch.
Aug 19, 2011 | Leviton DECORA TWO GROUNDING SWITCHES...
I have a D-Link DI 514 that I'd like to use as a relay/repeater for my WiFi. At home my Modem is a Westell Versalink 327w Gateway from Verizon. It works well but I'd like to extend access to my RV,...
OK you have a few options. Well first look at money. Your router is old so spending money on it may or may not be a good thing. You have a good router for its time but now it maybe time to move on. 2 new versions of routers have come out since you have had that version G and N and N being the newer of the 2. Moving on. If you want you can get a better antenna for it and you will get better range. they cost about $20 and up. Some have magnets so you can raise them higher and such. Also You can buy a repeater for it and extend the range of it but once again they cost about $50 and up. With the antenna you can put it up higher and get good range. They have new routers out (Version N) and you are using version B. If you go look for a new router go look for one that has MIMO (Multiple In Multiple Out). I don't care who you talk to at the store or what they say but one with this gives you longer range. Also one that has multiple external antennas. It will cost you a little more but your better off for what you want it to do. When all else fails with the new Router bring it back and get a different one and see if that you works for your needs.
Jun 22, 2011 | D-Link DI 514 Wireless Router (DI-514)
I would like to know what type of a CB radio I should buy for an 25 ft RV I have no clue. Price no problem.
any radio would do. it is the antenna on rv's that you need to watch. i normally make my own setups, but there are antennas for rv's by everbhart company which are no ground antennas, you would need this on all the new fiberglass body rv's, and the bigger the antenna the better it will perform anything smaller than 4ft the range is low.. But i normally make my customers there setups using a normal antennas and making a halfwave stub from coax the make the antenna a no ground system just like the factory ones. but i use rg58or8x to give a larger bandwidth (problem with factory rg174 types narrow bandwidth)... The radio type, either a cobra 25ltd if you have room, or if needing a compact unit try the cobra 19dxIII models or uniden pro 510xl.. the cobra 75wxst is an all in handheld unit which also is not a bad choice. 3174269649... If you need more help i would be glad to assist you.
Dec 07, 2010 | Radio Communications
Signal not strong enough can I boost it
The "Wireless / Advanced" configuration window contains a setting for transmit power. Be sure it is set to 100%.
Otherwise, your only options are to replace the antenna with a booster antenna, or to add a stronger wireless router as an access point to your current setup. Using a booster antenna requires the D-Link to have a removable antenna, which it may not have -- none of the documentation calls this out as a feature.
Keep in mind that if you are trying to use this router over excessive distances, boosting the router's own power will not necessarily improve your connection, because the broadcast power of the remote PCs is also a limiting factor.
Dec 02, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
Winegard RV7042 Wallplate/power Supply Model RV-7042 Logo
64 people viewed this question
Top Winegard Computers & Internet Experts
David Payne
David Payne
Are you a Winegard Computer and Internet Expert? Answer questions, earn points and help others
