Question about Sony HDR-FX1000 Mini DV Camcorder
Where can i find the internal battery of the FX1000e ?
How do you get to the internal battery on a G56 HP Laptop?
The error message refers to the battery on the bottom of the notebook that powers it when it's not connected to A/C power. If you go into the F2 at startup or use HP Support Assistant, you can run a comprehensive battery test
Mar 16, 2015 | HEWLETT-PACKARD HP G56-122US Notebook
Time setting on camera is lost every time i turn off ,changed battery, with correct one
The internal battery is depleted. In some cameras it will charge off of the removable battery after several hours, if the internal battery is still good. Otherwise you must replace the internal battery which is a watch type battery.
Mar 09, 2015 | Cameras
Please help me ... how can i transfer videos from my Sony HDR-FX1000E Camcorder tape to save it into my laptop (SonyVPCEB1M1E)? i will be waiting to hear from you... thanks a lot.
Transferring video from your FX1000E should be quite simple using an HDMI cable. If you've recorded in HD, the files may be quite large, so make sure there's enough space on your HD to accommodate them or the transfer will error out (which might be the problem you're experiencing). Once transferred, the most recent version of Windows Media Player should be able to play them. You may want to convert them to MP4 files to save some space too. If space is an issue, think about getting a 1TB external hard drive to transfer them to. You can then plug both the FX1000E into your laptop and the external drive into your laptop at the same time and when capturing the footage save it directly to the external drive.
Dec 28, 2010 | Sony HDR-FX1000 Mini DV Camcorder
My internal battery is depleted. how do i change
Do you meant Korg M1 ?
How to replace Korg M1 internal battery, read HERE
FixYa can only give you the guide requested but for DIY, you are responsible for your own repairs.
Jul 24, 2010 | Korg TR76 76 Key Synthesizer Workstation
My sony hdr fx 1000e pauses for a split second now and then on play back on the footage i have taken iits only a year old it has been sent back to the supplier and they said there nothing wrong but it has...
Yes I think this is the camera that records on the mini tapes yes? I have heard of this problem, and it is mostly dust, fluff round the capstan drives, if you clean the camera heads with a tape cleaner cass it should be okay.
David
Jun 22, 2010 | Sony HDR-FX1000E High Definition Camcorder
How to take out internal battery?
The internal battery is located under the cover for the AA batteries compartment.  The internal battery holder is located next to the middle battery of the line of three batteries.  The end of the holder has the internal battery size printed on it (CR 1220).
Jul 03, 2008 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot G6 Stopped Working
no, there is not an internal battery in canon g6 for operating it.
probably the battery does not touch the internal connectors of the camera.
May 10, 2008 | Canon PowerShot G6 Digital Camera
Date/Time problem
Hi all, same problem happened also with my S304. I' ve deassembled it and there IS an internal battery on one of the pcb's inside. So, i'm sure that if this is replaced by a new one, this problem should be fixed. Replacement will be a little bit tricky as the battery is soldered internally. If i have found the right type of battery, i'll post it, but this can take a little time ;-) F
Apr 23, 2007 | Fuji FinePix S304 Digital Camera
Sony HDR-FX1000 Mini DV Camcorder Logo
53 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
