How to fix a Saisho gas heater - Heating & Cooling
After a power cut I need to set the clock of my saisho MW2500 before it can be used. How do I do this please?
Hi, we had a similar problem on an old work microwave, and to get that to work, pushing ANY key allowed the unit to work, regardless of clock setting.
Worth a try.
Oct 05, 2016 | Microwave Ovens
Saisho sapd42g10 plasma tv is missing one of its parts suspected to be the control board, how can I find it
you must search in the internet. or call your supplie company in order to get help.
God bless you
Oct 12, 2013 | Microwave Ovens
Saisho microwave display dim
22ohm resistor on control panel or diode in rectifier short Re: Jeff
Apr 12, 2012 | Microwave Ovens
Pilot wont stay lit on waterheater. I replaced Thermocouple and that did not fix it. It will stay lit on vacation setting.
Most gas water heater problems can be fixed with yearly service that cleans burner and burner parts, checks gas pressure and bleeds air out of gas line, cleans air intake, and checks for venting and air intake problems.
Open following links for resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 27, 2011 | Water Heaters
The heater turns on for about a minute... green light then the red light turns on then it powers off.
the red light is to say burner on so its obviously faulting as its trying to light so i would be getting your service agent to look for you unless its just a simple case of your gas being turned off to heater, if the gas supply is not getting to heater it will fault when lighting so check all gas stop valves are on to heater if this is not the problem and your getting gas to heater there is a fault in the ignition somewhere so get a service agent to fix as gas heaters can be dangerous to play with i would suggest any fault on heater would need a service agent to fix i've seen people try to do thier own and i'm suprised that the house has not burnt down and worse yet by killing themselves its a gas heater and needs an expert to look at it for you!!!!!!!!!!!
Dec 09, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Comfort Glow Vent-free Gas Heater
I have a comfort glow gas heater that the pilot lights and when I start the heater it works for about 30 seconds then the whole thing shuts down.
Jan 02, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
