Question about Beko Fridge/freezer Thermostat Genuine 9002752885
How the fan for beko fridge. work.
Beko down cooler not cooling how can chick the fan
    New Friend:
  • 3 Answers
Please restate you question with better grammar & spelling.
Posted on May 07, 2014
Why does my fridge not cool,the fan doesn't kick on and the black little tank gets really hot?
A fridge operates due to adiabatics, which is the ability of a gas to absorb energy by compression, which turns to heat, then dispel heat by evaporation. The little black tank is a compressor which compresses the gas in the condensation loop. When the gas is compressed it heats up, so the little back tank will get hot, as will the condensation grid, often at the back of the fridge, which acts like a radiator to cool down the gas inside. When the gas is evaporated into the evaporation loop, it expands again and any rise in temperature caused by the compression will be lost. Add to this loss in temperature caused by the radiator and you have a total net loss in temperature which is significantly cooler than what you started with.
The problem with your fridge has to start with the fan not working as this fan will help to cool the condenser radiator, unless it is a fan inside the unit itself which just distributes the cool air. (without knowing the make an model of the fridge I cannot determine the reason for the fan). Modern low energy fridges have a better and more economical set-up and it seems that your fridge has seen better days. The compressor is clearly working overtime to get so hot and particularly if it never seems to shut down or the fridge cool down. Sadly, I think it's time for a new fridge. You'll save the money you are currently spending on the electricity to run the old one.
Sep 19, 2015 | Refrigerators
Why is the refrigerator section not cooling when the freezer is cold
THE REFRIGERATOR IS BASICALLY A BIG COOLER THE FAN IN THE FREEZER BLOWS THE AIR DOWN INTO THE REFRIGERATOR TO COOL IT SO YOUR FREEZER FAN IS PROBABLY OUT
Jun 11, 2014 | Frigidaire Refrigerators
I can't find Condenser Coil in Beko FN244 fridge
Good Afternoon GOODGIRL,
I see that you are wondering where the condenser coil and the cooling fan are located on your Beko FN244 refrigerator. I do see that your fridge is based out of the United Kingdom. I suggest contacting the manufacturer in the UK for further assistance. I have been able to locate a telephone number, of 08445 613 613, for your convenience. Hope this is helpful.
-Best Regards-
WP
May 07, 2014 | Frigidaire Refrigerators
Why is my fridge warm
There is a fan and a damper the blows cold air from freezer to refrigerator compartment. Damper is stuck closed or fan is not working is a good starting point.
May 07, 2017 | Whirlpool Refrigerators
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
Is it worth getting my fridge freezer fixed?
Check out the start cap/relay on compressor.
Apr 10, 2017 | Refrigerators
Hello. My fridge freezer is playing up. It's from John Lewis and is about 4 years old. The fridge was not reaching the right temperature and it was making a funny noise, so took it apart and found that...
most fridge-freezers send cold air from the freezer to cool the fridge. the flow is usually controlled by adjusting a 'warmer-cooler bar or wheel in the fridge. maybe you disturbed its original position while working on the fan.
Jun 19, 2017 | Refrigerators
Not cooling
first off see if the fans are running if not replace the cold control
Dec 18, 2009 | Refrigerators
My fidge wont cool down
Most likely a defrost problem..check the defrost thermostat, timer, heater, fan... if the fan in the freezer compartment running?? sometimes ice will form in the vents...check the easiest things first ..like the vents and drain tubes,,
Aug 20, 2008 | Refrigerators
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Beko Fridge/freezer Thermostat Genuine 9002752885 Logo
116 people viewed this question
Top Beko Refrigerators Experts
AJMAL KHAN
ray gallant
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
