Question about Zanussi ZWF1640 Front Load Washer
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
Hello, I'am Duong, and i have a Electrolux EWF1073 Front Load Washer, it does not working, so it has a error (code E40). When i start it runing, it run above ten minutes then stop, have three "tak" sounds and E40 code on LCD display. And i have check some item as: restart machine/open and close door again and restart/check the door switch but with the obove solution due not fix of the error. Please help me some solution for fix this problem. Thanks, Duong.
  • 1 more comment
  • Nguyen Van Duong
    Nguyen Van Duong May 10, 2014
    Can you help me ? And I opened the door switch (as image attached) and I don't no it has failure or not
  • Nguyen Van Duong
    Biger image
  • Nguyen Van Duong
    And i don't the control PCB fault or door switch fault. Can I short-circuit connect on cables (connection main control board to door switch at point 4 and 5 on image) ) to check what the main board has fault or not ?
  • 32 Answers
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
Posted on May 07, 2014
Testimonial: "Thanks Terry Miles, i have aready checked the drain hose, and clean it. But not fixed error. :(("
murdozzz2
  • 75 Answers
SOURCE: RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Posted on Dec 14, 2007
SOURCE: Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Posted on Nov 20, 2011
SOURCE: error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Posted on Apr 04, 2008
  • 3 Answers
SOURCE: zanussi iz 161s
e10 indicates a problem with water supply
Posted on Jan 19, 2009
  • 96 Answers
SOURCE: e40 error code
The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Posted on Mar 07, 2008
Built in machine. It show error e40. What does it meant
Hello Monica, thank you for your post!
Based off the information you have provided your Electrolux washer is displaying an error code of “E40”. I am showing that an “E40” error code means this could be an issue with your door swicth or main control board. I would recommend performing a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If you continue to receive the error code once power has been restored you may need to seek assistance from a professional technician for a proper diagnosis. Hopefully this information is helpful to you. –Matt
Mar 23, 2016 | Electrolux Washing Machines
What does e40 mean on a frigidaire washer
Hello plauano - Typically error code E40 indicates that the washer has detected a door switch or main control board problem. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes (this usually clear most false error codes). If it proves to be ineffective contact a professional to move forward accurately.
Jan 03, 2013 | Frigidaire ATF6000ES Front Load Washer
My electrolux washer dryer ewx14540w keeps flashing e40 and won't do anything, please help
Hi dear.Related to your problem,E40 means:
• The door is not firmly closed. (E40)
• The machine is not plugged in or there is no power
at the socket.
• The main fuse has blown.
• The type of fabric has not been selected by means of
the relevant selector dial.
• The Start/Pause button has not been depressed.
• The Delay Start option has been selected
Please checked those followings.I hope that helps.Thanks.
Feb 13, 2011 | Electrolux EW1209i Front Load Washer /...
I have a ewf1090 with an E40 error what can I check to see what is wrong
The code E40 indicates an internal loss of power, most likely caused by the door not been properly closed, either by a handling mistake or because the door latch is worn out.
There are a number of other conditions that may pop up the same message (i.e. overload due to defective motor, fuse blown), but unless you have any other symptoms like burned smell, I'd go for the door first.
The fuses are the second thing I'd check.
Jan 02, 2011 | Electrolux EW1000i Front Load Washer
Error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
May 21, 2010 | Electrolux EW1000i Front Load Washer
Error e40 come up on my washing machine zwd 1472 s
E40 normally points to a fault at the door switch,sometimes when the door switch fault occurs it can also cause damage to the main P.C.B.(Programmer).As this machine is still in the major parts warranty it would be advisable to get in touch with Electrolux.
May 03, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1640 Front Load Washer Logo
1,442 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
