Question about SanDisk Sansa m250 MP3 Player
M250 does not recognize some songs in the playlist
I have this problem with my Sansa m250:
-I upload the .mp3 files using "copy-paste".
-Then create a playlist using Winamp.
-When I open the playlist while the player is still plugged to computer, I can listen to the whole playlist in Winamp.
-But when I unplug and try to listen to the same playlist from the m250, it does not show some of the .mp3 files on the playlist. (i.e. the playlist contains 15 files, Sansa recognizes only 9 of them)
If you have any suggestions please let me know.
Thx.
  • 8,596 Answers
Use Windows Media Player to do this, not winamp
Posted on Jul 06, 2008
My Sansa M250 is only 1 month old and won't recognize Music folders now when I plug it in. My PC does recognize the device but now it only shows Audible, Config and Record. Before it showed playlist,...
reset the device to factory defaults thats it....
check your usb ports are working properly in not i recommend to re instal the usb device drivers also
Jun 27, 2011 | SanDisk Sansa m250 MP3 Player
How do i chare it with power and how upload the
The Sansa m250 uses one AAA battery, it doesn't charge.
To put songs on it, plug it into your computer via the wire it should have come with. The computer will take a while and then a box should pop up, where you can select to view files. Just drag and drop songs into that folder.
Jul 17, 2009 | SanDisk Sansa m250 MP3 Player
Cannot Copy Music
u want to convert the song into mp3format using real player.
Sep 18, 2008 | SanDisk Sansa m250 MP3 Player
Computer doesn't recognize MP3 player -
Don't transfer playlists - only transfer individual songs
Sep 15, 2008 | SanDisk Sansa Clip MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Rearrange songs on the SanDisk
Creating Playlists on the Sansa M240
The Sansa M240 is a decent device, but if you are like many, you have not been able to create playlists. The instructions with the player and the maker’s website offer little help. Here a solution that I found on-line with some additional detail. The step by step instructions for even those with little computer savvy.
1. power up your M240 player without connecting to your computer. Scroll thru the menu to the “settings” menu. Select “USB”, deselect “auto detect” then select “MSC”. (I don’t know if this step is critical, but I picked up this suggestion from another site)
2. Power down the MP240 and using the cable supplied with your player, connect to the USB port of your computer. The display will show “MSC” when connected.
3. If you have not already done so, download the songs you want to include on your playlist from your computer to the M240. Any number of media player software packages will allow you to copy or burn your songs to a “portable media device” for this step.
4. After your songs are downloaded, on your computer, go to “My Computer” and open the "Sansa M240" icon. On the explorer task bar, select “view”> “details”. You should see several standard folders and all your songs. (Note I have used this for both .wma and .mp3 formats and have intermixed them in the playlist)
5. On your computer, open a new Notepad document and save it to your desktop.
Name it whatever you like, but it has to have “.m3u” as a file extension when you save it.
For example I named mine…. playlist1.m3u, playlist2.m3u, playlist3.m3u.
6. Next, in this newly saved notepad document, type this exactly on the very first line < #EXTM3U > without the brackets.
7. Now, find your first song in the open M240 folder, place your cursor on it, right click and select "rename". When the song title is highlighted hit control + C or "Copy" the entire title, being careful not to change anything. Now place your cursor immediately after the #EXTM3U text, hit return and paste the title of your first song directly below it with NO line space in between.
8. Repeat the steps to copy the title of your next song from the M240 folder. When copied, place your cursor immediately after the previous song title copied in the step above. Hit return Twice to create a single line space after the song title and paste in the next song title at the beginning of the line. Repeat this process til you have built your playlist.
8. After you’ve entered your last song title, it should look something like this. (Either .mp3 or .wma extensions can be used)
#EXTM3U
First song.mp3
Second song.mp3
Third song.mp3
And so on.mp3
Now, within your notepad playlist document, click File/Save (noting where it was saved) and close the file. Now, find that same original playlist on your computer. Highlight it and copy / paste it onto your M240. I copied mine into a folder called “playlist” on the M240. Then I repeated the process for other playlists, giving each a unique name.
After allowing sufficient time for the file to copy, use the icon in the lower taskbar of your computer to “safely disconnect hardware” to unplug your player. Disconnect the USB cord, power up and your ready to enjoy your playlists.
Jan 28, 2008 | SanDisk Sansa m240 MP3 Player
I have Sanso m250 2.0gb mobel. Logo screen is appearing when i power on after that i am unable to play the mp3 songs or play FM Radio etc..
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. I do not know if this will work on other Sansa m200 type .mp3 players. You can start over with your playlists. This has worked for me.
Dec 23, 2007 | SanDisk Sansa m250 MP3 Player
How do i put a playlist on a sansa m240
#EXTM3U
First song.mp3
Second song.mp3
Third song.mp3
And so on.mp3
Mar 11, 2007 | SanDisk Sansa m240 MP3 Player
How to create multiple playslists for M250
Alright, well if you are adding songs to your MP3 player by using Windows Media Player, you can create playlists there, sort the songs into what playlists you want them in, right click the playlist, and click "add to sync list".
If you are manually copying and pasting the music into the mp3 player (that's how I do it) it's a little less obvious... For me there are three main folders: Music, Playlists, and RECORD. So we want to go to the playlists folder. In there, assuming you have at least one playlist already, you can copy and paste it, naming it something else and changing its properties as you see fit (right click -> properties). To add songs to the playlist, you go to it's properties, and under the references tab, drag the music files from wherever you have them stored and drop them in the references tab. This won't move your music, it'll just add them to the playlist. and.... guess that's about it. Hopefully that helped.
Feb 24, 2007 | SanDisk Sansa m250 MP3 Player
Can't create or play 'playlists'
Create your playlist with winamp and then copy it over with the songs listed in the playlist. You can make as many playlists as you like and they will show up under "playlist" on the screen
Jan 20, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
143 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
