Question about Retail Supplies
Paper for till pad
TK-6000/6500Where can l get the paper pad? Mine is old and unreadable
  • 592 Answers
Considering that ,that machine is still new , it will be hard for you to get it from a non dealer. Your best bet will be a casio dealer. Depending on where you are bur Casio is well represented world wide.
Posted on May 10, 2014
How to insert bond paper in the machine
Dear Jonna
You can use any bond paper from casset tray up to 105 GSM and that of from MP tray you can choose up to 160GSM. Also setting to be made from the device driver for the type of paper as it require more heat energy to fix the image to the paper.
Thanks.
Jan 12, 2015 | Kyocera Ite-Tk-18-1 Tk-18H Toner Kit 7200...
I have a Cash Register Casio TK-3200 and I am getting error 15 and is not listed in the error listing.. how do I fix it ??????
Hi Luis - Error code 015 refers to Receipt Paper End.
Error code 014: Receipt paper end (1/2) RECEIPT PAPER EN (plain English message)
Error code 015: Receipt paper end (2/2) D
There are several versions of the TK-3200 manual but this one lists the error code you want:
http://www.salopcashregisters.co.uk/pdf's/TK-3200.PDF
Aug 04, 2013 | Casio tk-3200 cash register
Paper does not feed properly
If the printer is less than 1 year old, spray AIR to clean residuous of paper. If its possible clean the paper pick up roller and separation pad w/ alcohol isopropilic or soap and warm water (peace of rag or quill tip soaked in warm water. If the machine is used heavily used replace paper pick up roller and separation pad.
Oct 23, 2012 | Canon PIXMA MX320 Color USB InkJet Printer
With my Casio TK-1550, I'm getting an E014 saying it's out of receipt paper. Even though I've inputted the receipt paper correctly the error still appears and I cannot relinquish any cash from...
I have had this before when the paper was the wrong size. make sure the paper is the same width as the printer and it is covering the little sensor on the printer. Make sure you have closed the platten arm down onto the paper fully. If this doesn't correct the problem, you may have to see a dealer. ---------------------------------------------------------------------------
If anyone needs more information, the Casio TK-1550 operating and programming manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1550_user_programming_manual.html
May 12, 2011 | Casio Parts Cash Register PC Desktop
Paper jamed in front roller where paper is taken from
It sounds like your paper pickup roller is worn down and can't grip the paper to pick it up. This roller is located on the bottom of the printer. Pull the paper tray all the way out and turn the printer over and you can see it as seen in the attached picture.
This roller comes in a kit along with the separation pad and the charge roller. When you replace one its best to replace them all. The roller kit is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Oct 17, 2009 | HP LaserJet 1320n Printer
Printer tray mispick
need to buy a "paper separation pad kit" once you get the new pad,remove the toner cartridge and with a long phillips screwdriver remove two screws that holds the paper feed roller,remove the roller and now you have a full view of the separation pad,with a little flat screwdriver PEEL the rubber from both separation pads the old inside the printer and the new one you just got,put the new rubber sep pad in the printer and put the paper feed roller back.....printer will work as new again....
Jul 29, 2009 | HP LaserJet 3200 All-In-One Printer
The document paper is crumpling as it enters the Fax Machine? I have cleared any old pieces of paper but it continues to crumple the paper???
In order for the documents to crease when entering the adf, there must be an obstruction. Since you have not mentioned the machine you have there it's harder to help. But, if you inspect the rollers and separation pad inside the adf, you may see that the sep pad has been dislodged or bent backwards or the rollers are dirty. If there is a sensor flag on your model, it may be stuck. Maybe there is a paper clip stuck somehwere along the paper path..
Jul 06, 2009 | Office Equipment & Supplies
Printing paper with to much toner ink on the paper. Words are unreadable.
If this is a cartridge refiling case,
I think its an over refill
try with refill again (complete empty (also waste) is necessary for best result)
May 21, 2009 | Brother Office Equipment & Supplies
Will not pull paper thru
. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Apr 04, 2009 | Office Equipment & Supplies
Paper Jam
There is a small clear plastic sheet that is suppose to be in front of the black friction pad in the paper tray. if that sheet is under the pad instead of in front of it you will get this error.
Mar 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Retail Supplies Logo
89 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
