Question about HP LaserJet 9050dn Printer
Problem with HP LaserJet 9050dn Printer 50.1 fuser error
50.1 fuser error
  • HP Master
  • 1,121 Answers
Low fuser temperature detected.
1. Remove & refix the fuser..
2. Replace the fuser...
Posted on May 07, 2014
Soulvisitor
  • 1113 Answers
SOURCE: HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Posted on Jan 09, 2008
SOURCE: Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Posted on Mar 28, 2008
  • 138 Answers
SOURCE: FUSER ERROR
I just reviewed both of the above fuser issues (50.2 & 50.3). Both are highly likely (even if recently replaced) fuser damaged. I have included below a link to a free HP service manual for your machines. Start on page 309 using a volt/ohms meter to test the fuser. To address the "Guest" inquiry regarding the HVPS, there is a separate HVPS however please be aware that it is not part of the fusing circuit in this machine. If anything it would be the LVPS (Low Voltage Power Supply) however very remote. Odds are maybe 1 in 200 on your best day. I'd put 10 fusers in the machine before I bought 1 LVPS. This machine is known to eat fusers. The HVPS and LVPS at this time are just about bulletproof. PLEASE TRY TESTING THE FUSER AGAIN USING THE MANUAL PAGE 309 TO 311. If your really want the power supplies though, they are on the part number list at the end of the manual. I just looked it up and we have repaired 74 of machines to date with not one PS ever used. 59 of the 74 have been for fuser issues.
Here's the manual link:
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%202820,%202830,%202840%20Parts,%20Service%20Manual.pdf
Hope that helps you both. :)
Posted on Sep 10, 2008
  • 47 Answers
SOURCE: 50.2 Fuser Error in HP Laserjet 2840
Printer connected straight to wallsocket,?check the fuser, remove it check for damages, and put it back, if error persist buy a new fuser.
Posted on Nov 24, 2008
SOURCE: 50.1 fuser error on HP 8150 LaserJet Printer
I have a HP LaserJet 5000 with a Fuser Error code 50.1, meaning low temp. I am not a tech, but I have been repairing my own cars, printing presses, computers, printers and anything else that breaks for over 35 years. The previous fuser on my LaserJet 5000 lasted over 7 years and while I was not getting any error codes, it was not fusing laser plates as well as I liked. Until recently I had two HP 5000 LaserJets and was able to trouble shoot by swapping parts. I replace a bad DC controller board in this particular printer about a year ago. Shortly after that I replaced the fuser with a genuine OEM HP fuser and it fused great for nearly a year. A few weeks ago I had a massive paper jam in the fuser and a day later got a Fuser Error 50.1. After checking the Internet I determined it might have broken the ceramic heating element. I swapped fuser with the one in my other identical working printer and the fuser error went away. I swapped the fusers back again and the error returned, pretty much proving the problem is in the fuser. Since I am not made of money I figured I could rebuild a fuser just as well as anyone else so I went on a search for the parts, but it was like calling Area 51 and asking what they were hiding. The service manual indicated some ohms testing to be done on the problem fuser and all results came back showing all the correct readings. I knew the fuser was the cause of the error, and the parts were not cheap so I carefully disassembled the fuser to see if I could isolate the exact part that was broken. The ceramic heating element and everything else looks fine. One detail I had found odd was that the printer used to take a couple of minutes or more to heat up, but I now got the fuser error 50.1 within 15 or 20 seconds of powering it on. This made me wonder if it would even have enough time to heat up enough to know it had a low temp problem. I thought the problem might be in the part that actually measured the temp. While I had the fuser apart I found one small resistor attached to the frame directly under the main drive gear. I did an ohms test on the resistor and it showed bad. I really hate to tear my good fuser apart to swap the resistors for fear I might burn it up to, so has anyone out there heard of a bad resistor causing a 50.1 error? I found only one reference on one site about a different LaserJet with a 50.1 code because of a bad resistor, and I have no idea where that resistor is on that particular printer. I know I could have just replaced the fuser by now, but I like to learn how things work and solve puzzles like this one. I am hoping some of my info may be of help to someone and if anyone has anyone ideas or thoughts on my comments, I would love to hear them. I will go on a search for a resistor next week and see if that helps. I hope to hear from someone soon. Thanks and God bless. James
Posted on Mar 08, 2010
One of our other Hp Laserjet 9050dn printer displays 'Output bin full and Jam paper. What could be wrong.
There must be a problem with the output sensor, dirty, bent or clogged. Check all the paper paths and if possible reset the error code. Regards, Mike
Jan 27, 2016 | HP LaserJet 9050dn Printer
How to fix hp 9050dn 49.2F83 error
it is a communication error delet the print job it is corrupted some how. usually when printing pdf files. if this does not take care of it it will be your formatter board.
Dec 22, 2015 | HP LaserJet 9050dn Printer
I try to use my HP laserjet 9050dn printer this morning and it shows Error 59.40. What could be the cause?
This error indicates a problem with the fuser motor. Can be either the motor or might be the fuser.
Aug 13, 2015 | HP LaserJet 9050dn Printer
50.1 fuser error
Usually means the heater temperature has not been reached or has over heated. Usually means the fuser needs replacing. Always try taking the fuser out first and then re-fitting it in case there is a poor contact.
May 07, 2014 | HP LaserJet 9050dn Printer
The printer is HP LaserJet III . Please - what means the message "50 service " on the panel ? Thank you! MP
A 50.4 code is bad line voltage. Don't plug it in a surge protector.
Any other 50 error is a fuser problem. Turn the printer off for at least 10 minutes. Power it back on. If the error returns, replace the fuser.
Oct 21, 2010 | HP LaserJet IIIp Printer
HP 9050dn smearing on sheets. Replaced fuser twice and still has problem
Try replacing the drum unit. when they wear out, you'll get toner smears.
Aug 18, 2009 | HP Hewlett Packard LaserJet 9050dn Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
HP LaserJet 9050dn Printer Logo
251 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
