Question about Apple iPod nano
4gb 2nd generation nano has gray screen with vertical lines
It will light up if you toggle the hold button a few times or press the on button, but all i get is a gray screen with slight vertical lines -- my computer recognizes it and will even say it has synced. I did the restore process from itunes and also did the 5 step process that apple suggests with no success -- could the lcd just be permanently damaged or just failed? i think i have dropped it just once and that was on soft carpet. It started doing this intermittently and then just wouldn't give the normal screen back at all now.
Thanks!
  • 317 Answers
SOURCE: apple ipod nano wont play the full song
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Posted on Jan 09, 2008
  • 31 Answers
SOURCE: Frozen iPod nano
try to put the ipod into disk mode, while connected to PC, perform first hard reset by holding select and menu buttons until it restarts, when quickly change to pressing select and play buttons, then it must go into disk mode, will sync with PC and must show in iTunes, perform restore function to reformat the memory
Posted on Aug 20, 2007
SOURCE: itunes 2nd generation nano "use itunes to restore" then the restore doesnt work
push all the button, unconnect it and connect it several time then it should worrk, it did for me;-)
Posted on Feb 05, 2008
  • 13433 Answers
SOURCE: My 4gb nano froze up on me can you help me get it unlocked?
ResetTo reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Posted on Apr 01, 2008
  • 13433 Answers
SOURCE: black and white screen and not recognized.
try this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
note in the end of my post there is the online service assistant where you can check your warranty and setup repairs with apple if required.
Posted on Jul 28, 2008
I have a 4th generation pink 8gb ipod nano the
To factory reset on my ipod classic...  slide the hold switch to hold  then slide it back  then press the center and menu button for up to 60 seconds.
Nov 10, 2009 | Apple iPod nano
Tip
To get your 4GB iPod Nano to be recognized by your computer
I found the solution to this problem:
To get your iPod Nano 3rd Generation (4GB video) to be recognized by your computer, you will need to manually get it into "Disk Mode" here's how:
  1. Verify that it has a full charge, if not, you need to either charge the iPod before continuing or connect it to a high-powered USB port, or simply connect it to the Power Adapter that plugs into an electrical outlet. (just not connected to your computer)
  2. Toggle the Hold switch on and off once. (Set it to Hold, and then turn it off again. Just slide back and forth.)
  3. Press and hold the Menu and Select (center) buttons at the same time for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select (center) buttons and immediately press and hold the Select (center) and the Play/Pause buttons until the ‘Disk Mode’ screen appears.
  5. Disconnect your iPod from the power adapter and connect it to your computer;
  6. Now the screen on the iPod will change and say "Do not disconnect" and should be recognized by your computer.
I hope this helps you; I had a hard time finding a solution and thought I'd share the wealth once my stress was relieved.
on Sep 11, 2009 | Apple iPod nano
The unit will not turn on nor charge.
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Apr 20, 2009 | Apple iPod nano
I have n ipod nano 2nd generation which has frozen, and although I have toggled the hold button and then held the center button and the play/pause button down it will not reset. Can you tell me what to do...
I toggled the hold key on and off and then held the MENU and CENTRE buttons down until the apple sign came up and it now works fine. I had to do the procedure a few times but it eventually worked.
Mar 02, 2009 | Apple iPod nano
Nano 4GB battery doesn't stay charged
im gonna suggest you the best way:
Toggle hold switch on.
Toggle hold switch off.
Hold down the menu and middle button for a few seconds.
You might need to repeat.
Feb 10, 2008 | Apple iPod nano
Ipod 30g
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Nov 30, 2007 | Apple iPod MA446LL/A MP3 Player
30 GB Ipod Video Problem - Its locked
  • iPod classic
  • iPod nano
  • iPod mini
Nov 27, 2007 | Apple iPod MA446LL/A MP3 Player
When turning on my iPod keeps saying to go to the Apple web site for support
  • iPod classic
  • iPod nano
  • iPod mini
Nov 26, 2007 | Apple iPod MA446LL/A MP3 Player
My ipod was hang!
ya just hold the menu and center button till an apple image appears on screen!
Nov 13, 2007 | Apple iPod MA446LL/A MP3 Player
Sync problem
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 07, 2007 | Apple iPod nano
Apple iPod nano Logo
791 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
