Question about HP Office Equipment & Supplies
Hp 9050dn fuser error 50.1 - HP Office Equipment & Supplies
  • HP Master
  • 1,121 Answers
Fuser Low temperature detected.
1. Remove & refix the fuser..
2. Repalce the fuser..
Posted on May 07, 2014
no_pc-gst
  • 58 Answers
SOURCE: 50 .2 Fuser Error in
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Posted on Dec 31, 2008
SOURCE: 50.1 fuser error on HP 8150 LaserJet Printer
I have a HP LaserJet 5000 with a Fuser Error code 50.1, meaning low temp. I am not a tech, but I have been repairing my own cars, printing presses, computers, printers and anything else that breaks for over 35 years. The previous fuser on my LaserJet 5000 lasted over 7 years and while I was not getting any error codes, it was not fusing laser plates as well as I liked. Until recently I had two HP 5000 LaserJets and was able to trouble shoot by swapping parts. I replace a bad DC controller board in this particular printer about a year ago. Shortly after that I replaced the fuser with a genuine OEM HP fuser and it fused great for nearly a year. A few weeks ago I had a massive paper jam in the fuser and a day later got a Fuser Error 50.1. After checking the Internet I determined it might have broken the ceramic heating element. I swapped fuser with the one in my other identical working printer and the fuser error went away. I swapped the fusers back again and the error returned, pretty much proving the problem is in the fuser. Since I am not made of money I figured I could rebuild a fuser just as well as anyone else so I went on a search for the parts, but it was like calling Area 51 and asking what they were hiding. The service manual indicated some ohms testing to be done on the problem fuser and all results came back showing all the correct readings. I knew the fuser was the cause of the error, and the parts were not cheap so I carefully disassembled the fuser to see if I could isolate the exact part that was broken. The ceramic heating element and everything else looks fine. One detail I had found odd was that the printer used to take a couple of minutes or more to heat up, but I now got the fuser error 50.1 within 15 or 20 seconds of powering it on. This made me wonder if it would even have enough time to heat up enough to know it had a low temp problem. I thought the problem might be in the part that actually measured the temp. While I had the fuser apart I found one small resistor attached to the frame directly under the main drive gear. I did an ohms test on the resistor and it showed bad. I really hate to tear my good fuser apart to swap the resistors for fear I might burn it up to, so has anyone out there heard of a bad resistor causing a 50.1 error? I found only one reference on one site about a different LaserJet with a 50.1 code because of a bad resistor, and I have no idea where that resistor is on that particular printer. I know I could have just replaced the fuser by now, but I like to learn how things work and solve puzzles like this one. I am hoping some of my info may be of help to someone and if anyone has anyone ideas or thoughts on my comments, I would love to hear them. I will go on a search for a resistor next week and see if that helps. I hope to hear from someone soon. Thanks and God bless. James
Posted on Mar 08, 2010
SOURCE: HP 3505n message: 50.9 Fuser Error Fuser is
Please replace the fuser assembly.
Posted on Sep 27, 2010
tballone
  • 126 Answers
SOURCE: I Have HP Laserjet 3055
You can reseat the fuser or you will have to replace the fuser. Please note the these machines the fuser is located in the middle of the machine. Most likley it's a bad fuser.
Posted on Oct 19, 2010
  • 731 Answers
SOURCE: 50 fuser error in hp
An error 50 on most HP Laserjet printer indicates the fuser has a problem. Most common problem is the heat lamp burned oou. The lamp is not a replaceable item unless you re a top notch technician. The fusing assembly however is usually a relatively easy replacement requireing only twisting of a couple of latches or removal of a couple of phillips screws.
The part # for the fusing asm for the HP LJ 3030 is RM1-0865-000CN.
These can readily be found online for anywheres from $120 to $250.
Posted on Dec 18, 2010
One of our other Hp Laserjet 9050dn printer displays 'Output bin full and Jam paper. What could be wrong.
There must be a problem with the output sensor, dirty, bent or clogged. Check all the paper paths and if possible reset the error code. Regards, Mike
Jan 27, 2016 | HP LaserJet 9050dn Printer
How to fix hp 9050dn 49.2F83 error
it is a communication error delet the print job it is corrupted some how. usually when printing pdf files. if this does not take care of it it will be your formatter board.
Dec 22, 2015 | HP LaserJet 9050dn Printer
I try to use my HP laserjet 9050dn printer this morning and it shows Error 59.40. What could be the cause?
This error indicates a problem with the fuser motor. Can be either the motor or might be the fuser.
Aug 13, 2015 | HP LaserJet 9050dn Printer
Problem with HP LaserJet 9050dn Printer 50.1 fuser error
Low fuser temperature detected.
2. Replace the fuser...
May 07, 2014 | HP LaserJet 9050dn Printer
50.1 fuser error
Usually means the heater temperature has not been reached or has over heated. Usually means the fuser needs replacing. Always try taking the fuser out first and then re-fitting it in case there is a poor contact.
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
HP 9050dn smearing on sheets. Replaced fuser twice and still has problem
Try replacing the drum unit. when they wear out, you'll get toner smears.
Aug 18, 2009 | HP Hewlett Packard LaserJet 9050dn Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
184 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
