Question about Gateway Computers & Internet
Slui.exe application error 0xc0000185 in my laptops
3 Suggested Answers
  • 45 Answers
SOURCE: DirectDBNotifyWndProc:msimn.exe-Application Error
http://www.insideoe.com/
Posted on Jan 07, 2008
  • 377 Answers
SOURCE: I was restoring my computer using Window 7 and get
Many users who experience slui exe errors are in the dark about how to fix these types of problems. Fortunately for all of us, the bulk of them can easily be pinpointed and fixed, even if you have very basic technical skills. In the next few paragraphs, I would like to show you how you can effectively do away with these troublesome computer problems.
go trough this link and repair you pc
http://www.topregistrysolutions.com/exe?cd=EXl1792
Posted on Sep 02, 2010
Dl'ed Spy bot on Toshiba Satellite laptop turned my laptop on there is a repair error 0xc0000185 cant auto repair. Is there anything I can do to get it back up?
The 0xc0000185 error simply means that the computer can't communicate with the CD drive. It could be due to a faulty CD drive or media, a bad connection, faulty interface, bad memory, power supply etc. You will need to isolate the problem further, why couldn't you boot normally? check the BIOS settings again and try clearing the CMOS memory correctly as described in the manual (just removing the battery may not be good enough).
Apr 30, 2016 | Toshiba Satellite Computers & Internet
Windows & will not start. Status 0xc0000185
Your laptop cannot communicate with the hdd.
Try the link.
Windows 8 Error Code 0xc0000185
Apr 25, 2016 | Computers & Internet
0xc000185 error
How to fix The Specific Code Is 0xc0000185 errors? There are several methods of fixing The Specific Code Is 0xc0000185 errors. You may need to try more than one method before you're successful.
Download the (The Specific Error Code Is 0xc0000185) repair tool. avg-linkscanner-verisign-safe.jpg Install the program and click on the Scan button. Fix any errors it finds once the scan is complete. Restart your computer.
• Manually edit your Windows registry. Start the registry dditor by clicking the Start button, typing regedit in the Search box, and pressing Enter. Open the HKEY_LOCAL_MACHINE folder ==> "Software" folder ==> "Microsoft" folder==> "Windows" folder ==> "Currentversion" folder. Click on the Run folder ==> Click on the The Specific Error Code Is 0xc0000185 file. Delete the file by pressing Delete The Specific Error Code Is 0xc0000185 key. You can then reinstall the file on your PC
• Update the drivers for the device. It's possible that installing the latest drivers for the device could correct the error. If this works, it means that the existing drivers you reinstalled in the step above may well have been damaged.
• You can also download the Windows The Specific Error Code Is 0xc0000185 recovery utility which has proven successful at fixing this error..
Feb 17, 2014 | Samsung Computers & Internet
Error 0xc0000185
A 0xc0000185 error is usally a regestry error and there are two possible fixs, 1 is to reinstal windows or if you have a system reserve partiton you can resore windows with that both of these may and proberbly will lead to data loss, 2 is you can use a registry repairing program such as CCleaner to repair the registry,
Good luck ;)
Oct 19, 2013 | Acer Aspire 5315 Notebook
Code error 0xc0000185
Follow these steps
First you should Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
- Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing blue screen
Jul 03, 2013 | Sony VAIO Computers & Internet
O error 0xc0000185
This error can occur when there is a problem in reading and/or verifying data on the HDD/SDD. The most common cause is a loose data connection, although the power connection can cause similar issues. Check the connections at both ends of the cables. Also check the connections to your optical drive and make sure that your RAM is correctly seated. Since you have already opened your laptop to do prior maintenance, it is quite possible that you have dislodged one or more cables without realising it. By the sounds of it, your laptop continued to work for a short while before failing again with your current issue. It is likely that a sudden sharp knock might have caused a loose connection to become disconnected.
Apr 23, 2013 | Acer Computers & Internet
ERROR CODE 0xc0000185
Mar 19, 2013 | HP Pavilion Computers & Internet
I was restoring my computer using Window 7 and get a error message and now I am stuck Can you help me slui.exe application error unable to start correctly (oxoooo7b)
Sep 02, 2010 | Gateway GT5028 PC Desktop
I am unable to do anything on my computer
you got virus, and Trojan on your laptop.
need to go buy a good antivirus software. i.e. symantec, McAfee, etc..........
ask the sales person in the store.
scan the laptop.
Nov 14, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
