Question about Sony PlayStation® 3 (60 GB) Console
LCD outputs 120Hz, but only 60Hz when PS3 is connected via HDMI
I was informed the PS3 Blu-ray & gaming would be at 120Hz. Why isn't at 120Hz?
  • CODTerrorist Jun 23, 2009
    I solved my own problem. Thanx to me. Anyone has the same problem as I did, get at me!!
  • CODTerrorist Jul 16, 2009
    dvsmind79,
    If you have a TV that puts out 120hz, but on the display it only shows 60hz, don't worry about it. On any outputs such as PS3, Cable box, DVD player, etc...it is going to automatically show in 120hz. What you have to make sure you have is the Monster cable - that made a HUGE difference - I was recommended to purchase the $79.99 Monster cable & that fixed the problem...now all my blu-ray movies show in 120hz as well as gaming...if you have any other problems or questions, email me at bluetwenty6@yahoo.com.
CODTerroist,
How did you fix this issue??... I need help please
thanks
Posted on Jul 16, 2009
I have red,yellow& white come out my dvd and only white & red plug in on the back of my tv how do i make that work and which source and channel i put the tv on
Red and White are audio, yellow is video. On the back of the TV there should be a yellow jack if it takes external inputs. There are two ways to connect your Blu-ray Player to your amplifier. Via HDMI output: Connect the player's HDMI OUTPUT to the corresponding INPUT on your amplifier using an HDMI cable. If your amplifier has an HDMI OUTPUT, connect that to the HDMI INPUT on your TV using an HDMI cable. See if these links help.
Five Tips to Successfully Set Up Your Blu ray Player How to hook up your Sony Blu ray player to TV How to Connect TV to Blu Ray Player CONNECTING YOUR SMART BLU RAY PLAYER TO YOUR TV
Obviously if you gave better information you would get a better answer.
May 30, 2016 | Televison & Video
How to you connect PS3 to to model 37PD5000
Good day!!!
Please try this procedure to connect the PS3 to TV..
The PS3 has a Blu-ray drive that can be used not only for playing games but also for watching high-definition movies. The best way to connect a PS3 to a high-definition viewing device such as a video projector is through the PS3's high-definition multimedia interface (HDMI) output. The HDMI connection can transmit up to 1080p high-definition from the PS3 to the video projector using a single cable. Attaching and setting up the HDMI cable will only take a few minutes and will let you watch high-definition video from the PS3 on the video projector.
  1. Connecting HDMI
    • Attach one end of the HDMI cable to the HDMI output connector of the PS3. Turn the HDMI cable around if it does not slip right into the HDMI output, because the HDMI cable can only fit into an HDMI connector one way.
      Attach the other end of the HDMI cable to the HDMI input connector that is on the video projector. Make sure both sides of the HDMI cable is securely pushed into the connectors of the PS3 and of the video projector. Turn on the video projector. Press the "Menu" button on the video projector's remote. Navigate to the "Sources" setting on the video projector's Menu. Select "HDMI" from the "Sources" setting. Press the "Menu" button on the remote control again to exit the Menu.
    Adjusting the PS3
    • Turn on the PS3. Wait for the "Home" menu to appear on the video projector, although the quality of the video seen from the video projector will be muddied and dark. Navigate from the "Home" menu to the "Systems" icon using the game controller and select the "Display Settings" tab. Choose "Video Output Settings" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen.
      Choose "HDMI" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen. Choose "Automatic" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the "Confirmation" screen. Press the "X" button on the game controller to make the settings active. Return to the PS3's "Home" menu.
    Watching the PS3
    • Insert a Blu-ray disc into the slot at the front of the PS3. Wait as the Blu-ray disc begins to play the video content on the video projector from the PS3 through the HDMI cable.
Please don't forget to rate my answer...I really appreciate any ratings you done..
Thanks for using fixya..
Jul 16, 2011 | Hitachi 37PD5000 Television
Surround sound signal not transferring.
need to go into audio menu and select digital audio as the output signal, its probably set to mts stereo.
Aug 29, 2009 | Insignia 42" LCD Flat-Panel HDTV
Game plays in 1920/1080p **60Hz**. i have a LED 120Hz TV.
the tv only gives out as much as it can, you cant improve it, srry
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont go 1080i/720p
I don't think there is a way to set your resolution manually, bro. They do it all by auto. If I may make a suggestion... Turn off both the TV & PS3. Unplug your HDMI, then make sure both your TV & PS3 are turned ON. Now re-connect your HDMI. A TV tech once told me that these units "communicate" through the HDMI. This can only occure whilst they're up & running. This may help get you going on to 1080i.
p.s. PS3 games only output 720p, max! This isn't always the case for Blu Ray movies, but it is for games. Good luck!
May 23, 2009 | Sony PlayStation® 3 (60 GB) Console
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Mar 19, 2009 | Yamaha RX-V463 Receiver
My PS3 display is flashing...
On the XMB go to Settings ---> BD/DVD Settings ---> BD 1080p 24 Hz Output (HDMI). Turn that bad boy off.
Give that a shot.
Feb 20, 2009 | Sony Playstation 3 (PS3) Console
Sony ps3 an samsung tv
Well your PS3 Can't connect with your TV to the Samsung, because PS3 Was made HD Blu-Ray. If your TV/Samsung is not supported by High Def. or Blu-Ray, it will not work, you will need a different HDMI Cable, and it should work fine.
Hope this Helped.
Jul 12, 2008 | Sony Playstation 3 (PS3) Console
Ps3 not playing blu ray on my samsung LCD
Change the frame rate on your tv to 60hd, that should solve it. Basically, your tv might be set to theater mode which is playing 24hd..
May 14, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
1,936 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
