Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
The sel/push exec dial on my PD170 doesn't seem to be working properly. Is there a fix for this?
3 Suggested Answers
raymondguy
  • 3 Answers
SOURCE: menu select dial problem
It will not let me out of the title area. The menu will only show me the option under the different headings but will not go to the format section nor other sun sections. Have tried a new memory stick and get the fast blinking error with the new one too.
Posted on Feb 26, 2008
SOURCE: About every 10 minutes, the camera goes through
put in a cassette
Posted on Oct 09, 2009
Explain in plain english how this works. Set time on face rotating dial clockwise.. push in pins to on and off positions. It seems to screwy unless timer runs counterclockwise, Set time at 5:30 AM amd go...
For starters, disregard which way the timer runs. Push in the pins for when you want it to power your lights. Turn the dial to set the time of day that it is now. That should be it.
Dec 04, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
How do I change from LP to SP ?
for the dcrtrv320 here's how you do it.ensure you have the power switch set to camera/vtr. press the menu button. will give you little icons on the screen (you should see manual set or vtr set). scroll down to the icon the looks like a tape (tape set). use the sel/push exec dial (it's the dial near the menu button,bottom of the viewfinder and left side of the batt) you scroll it up/down and push it in to confirm your selection.in tape set you have rec mode (press sel/push exec dial in)scroll to sp and press sel/push exec dial again to confirm setting. press menu to exit menu settings. hope this helps.thanks :)
Mar 26, 2010 | Sony Handycam DCR-TRV320 Digital Camcorder
My dsr pd170 lcd view screen is viewing in negative imaging. it seems to be filming fine, but the image quality slowly degrades while filming. Since we work at a camp and film things like talent shows...
dear
first tell me when u close the lcd pannel , then is the view finder working fine , if not then
view finder cable is broken . u cant fix it your self as u need to open the camcorder .you must not be having the proper tools for that.
and regarding the lcd part , if the display is fine for a while ..and then
while using it it goes fade , shows grey colour or lines in it . then its lcd problem ...ur lcd need to be replaced .
Jul 25, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Setting the time on a kd-g430
CLICK HERE for your installation manual in PDF format.
Page 7 states the following....
1. Press and hold SEL button
2. Select CLOCK H (hour) or CLOCK M(min) by using the |<< & >>| buttons and rotating the volume dial to select the number desired.
3. Press SEL to finish and exit.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE Question.
Jun 03, 2009 | JVC KD-G430 CD Player
I want to put color bar in pd 170
dear when u will open menu .. at last where we check ..HR. METER ,if u remmber ...
der is the option for the colour bar
Jan 25, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony DSR-PD170 Color Problem
sounds like a problem with the image sensor, or an intermittent cable connection to the sensor.
Jan 06, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Menu select dial problem
preset Titles? can you describe the problem with more detail please. sounds sort of like you need to get into the menu and swith it out of title mode.
Jun 13, 2007 | Sony Handycam DCR-TRV730 Digital Camcorder
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
37 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
