The buttons on my hotpoint aquarius wt740 don't work
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Aquarius WT740 Fault Code
Hi. F05 means pressure switch jammed on full.
Check pump for blockage and that it is working, if no joy you will have to call an engineer
Posted on Nov 20, 2008
WT740 Hotpoint Aquarius Plus Washing Machine
it sounds like the Bord on the front panel has been pushed back ..unplug the machine take lid off and nicely push the Bord in you should see by clicking the on off button if you have done it hope this has helped if not then it sound like a Bord problem with Bord is up to you how far you want to take the machine apart ok you can get back to me after you have tried to push the Bord back ok
Oct 22, 2012 | Washing Machines
I have a code on the display f-08
hotpoint washing machine WT740 1400 code erroe F-08 flashing machine stops working after 20 minutes please help
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi i have a hotpoint washin machine and it kepp showing H20 on the csreen can you please help th model number is WT740
H20 indicates a problem with water supply.
Check the inlet hose/s for restrriction or kinks, ensure water supply pressure is o/k, also check the filter screens in the inlet valves, you will have to turn the water off to do this.
Dec 06, 2010 | Hotpoint Aquarius WD63 Front Load...
I cannot open the door on my Hotpoint Aquarius wt740 after it finished a wash. Door handle is floppy and door light is off.
it sounds like you have a broken door handle Disconnect power before doing anthing remove lid , what you will need to do is usining a screw driver or somthing simular look down to where the catch is (you may need a tourch) and look carefully you should be able to to the door catch mechanisim from inside you will need to mimic the action of the door handel but using a screw driver it a bit fiddley but can be done there is no grate force needed and it the catch will only need to move a bout 3-8 mm to open
Jan 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The start button on my hotpoint wt740 washing machine wont click on.
Hotpoint had a problem with a control panel design where if the start button is pushed too hard, it snaps off the panel. This is most likely cause but it might be a faulty door lock.
Dec 09, 2009 | Hotpoint Washing Machines
Fault code stopping washer from working
My washing machine will not spin and in fact turn around at all, i did a wash earlier and it was making a funny noise...like some thing was caught in the drum. It is about 3 years old....It does still fill with water thou!
May 24, 2009 | Ariston Technologies Washing Machines
Hotpoint Aquarius WT740 Fault Code F-05. What does this mean?
Nov 18, 2008 | Washing Machines
Hotpoint error f10 on model wt740
F10 us usually a stuck key on the keypad. Turn the power off to the machine or kick the breaker off, press each button a number of times to make sure they are not sticking. If you find one sticking try to pop it out. Turn the power back on and try to use it. If the f-10 code returns you will need a new touchpad. Good luck to you and I hope this helped you. Mike Anderson
May 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
