Question about Casio Office Equipment & Supplies
Int? will not clear from input screen ? - Casio Office Equipment & Supplies
Wirte a pogram in java using for loop,that will print out the first 1 numbers of a fibonacii series that is:1 1 2 3 5 13 21 34 55
package com.gpt;
import javax.swing.JOptionPane;
This program computes Fibonacci numbers using a recursive
method.
public class Fibonacci
public static void main(String[] args)
String input = JOptionPane.showInputDialog("Enter n: ");
int n = Integer.parseInt(input);
for (int i = 1; i {
int f = fib(i);
System.out.println("fib(" + i + ") = " + f);
System.exit(0);
Computes a Fibonacci number.
@param n an integer
@return the nth Fibonacci number
public static int fib(int n)
if (n return 1;
else
return fib(n - 1) + fib(n - 2);
Feb 24, 2011 | Sun Java Programming Language (cdj-275)
Declare 2 arrays with 5 as index value of each. the user will input values to the first array(user-defined). Transfer value of the first array to the second array.Get the sum of the second...
You could do this by creating two arrays as such:
int firstArray[5]; int secondArray[5]
and then the sum variable:
int sum = 0;
then you could do a for loop to find the sum of the second array:
Feb 22, 2011 | Microsoft Visual C++ Professional Edition...
How to write an electricity bill in c program(9'th class)
#include <iostream.h>
#include <conio.h>
int main()
clrscr();
long int units,charge=0;
float total;
const int rent=25;
cout << "Enter the number of units used : ";
cin>>units;
if(units>200)
charge=(units-200)*20+150*40+50*60;
else if(units>50)
charge=(units-50)*40+50*60;
else
charge=units*60;
total=0.01*charge+rent;
cout << "You have used " << units << " units." << endl;
cout << "Your total telephone bill is $" << total;
getch();
return 0;
Please accept the solution. Thanks, Lucy
This program takes in the number of units used ('units') as a screen input from the user.
It then calculates the total telephone bill for the customer on the following basis :
A compulsory fee of $25, plus
60 cents per unit for the first 50 units,
40 cents per unit for the next 150 units,
20 cents per unit for anything above 200 units.
It then outputs the bill using the 'cout' command.
Jan 12, 2011 | Microsoft Computers & Internet
A java code for anagram
import java.io.IOException;
public class AnagramApp {
static int size;
static int count;
static char[] charArray;
public static void main(String[] args) throws IOException {
String input = "Java Source and Support";
size = input.length();
count = 0;
charArray = new char[size];
for (int j = 0; j < size; j++)
charArray[j] = input.charAt(j);
doAnagram(size);
public static void doAnagram(int newSize) {
int limit;
if (newSize == 1) // if too small, return;
return;
// for each position,
for (int i = 0; i < newSize; i++) {
doAnagram(newSize - 1); // anagram remaining
if (newSize == 2) // if innermost,
display();
rotate(newSize); // rotate word
// rotate left all chars from position to end
public static void rotate(int newSize) {
int i;
int position = size - newSize;
// save first letter
char temp = charArray[position];
//shift others left
for (i = position + 1; i < size; i++)
charArray[i - 1] = charArray[i];
//put first on right
charArray[i - 1] = temp;
public static void display() {
System.out.print(++count + " ");
for (int i = 0; i < size; i++)
System.out.print(charArray[i]);
System.out.println();
Nov 22, 2010 | Computers & Internet
How to put input on a samsung plasma? I have a samsung plasma and I am trying to connect an Xbox, can someone help?
you will have to use component cables with rca's
from xbox plug to rca to plasmas component input
use your plasmas remote to locate a channel to tune int channel o your xbox,when you turn on xbox the start screen should show,dont need a disk for tuning just playing
go forth and have fun .
Cheers MISTERDJ
Apr 11, 2010 | Samsung (TN-RBNG10) TV Input
My Sharp AR - 2005 copier flashes H and 4 alternately on the number of copies screen What can I do to resolve this?
A H4 code on this machine means a Thermistor issue.
The thermistor messures how hot the hot section gets indide your machine. This code is re-setable though =]..
If it is the machine im thinking of, it is actually a AR-205.
To get into service mode press
*** c, (int), 0, (int) ***
>> (Clear, Interrupt, Zero, Interrupt)
The screen should then go blank,
Simply enter "14" then press the copy button.
The machine will reset, and the code will be gone.
If there is something seriously wrong with the thermistor though. The code will come back fairly soon, and in that case you will have to get a Authorized Sharp Agent to replace this part =]
ta!
Aug 18, 2009 | Sharp Office Equipment & Supplies
L 6 CODE ON SHARP ARM205 HOW DO I REPAIR PLEASE
L6 is a Polygon Motor Lock.
Unfortuantly there isn't a whole lot you can do. You can try and reset the code, but most likely you will need a Certified Sharp Rep to replace your LSU.
To reset,
Make sure your machine is awake and ready to copy.
Simply press,
c, *int*, 0, *int*
(Clear, interrupt, zero, interupt)
The machines screen will flash blank.
Simply type in
'14'
and press copy.
The machine will reset the code and restart.
If this does not work enter sp modes again.
and try code '16'
Ta!
Willi Williams
Service Engineer.
Aug 17, 2009 | Sharp Office Equipment & Supplies
I can't find how to input Int on my calculator
Hi. Many of the fx 9750's functions are hidden; they are accessed via the 6 grey F keys under the display. To use Int, Frac, Abs functions, after you turn on your calculator, in normal mode (menu 1 selection), press [OPTN] [F6] [ F4]
This will give you the number menu, containing Abs, Int, Frac, Rnd and Intg
Int is the F2 key. Press [F2] first, then enter number or variable. Int value will be shown.
Hope this helps.
Mar 11, 2009 | Casio FX-9750GPlus Calculator
Input a number and then show the fibonacci sequence of the input number in a C++ program.
I'm assuming one of two things, either
A) You need help for a programming class?
or
B) You're just curious?
Either way
#include <iostream>
#include <algorithm>
using std::swap;
using std::cout;
using std::endl;
// Function f returns n'th Fibonacci number
// It uses Algorithm 2C: non-recursive loop
unsigned int f(unsigned int x) {
unsigned int x1=1;
for(unsigned int i=1,x2=1;i<=x;i++) {
x1+=x2;
swap(x1,x2);
return x1;
// Function f_print prints out n'th Fibonacci number
void f_print(int n) {
cout << n << "th Fibonacci number is " << f(n) << endl;
// main is the entry point in C++
int main() {
f_print(46);
Feb 18, 2009 | Computers & Internet
A c prog to convert decimal to hexadecimal number.
Sure, here you go:
int main(void) {
int input;
printf("Enter a decimal number: ");
scanf("%d", &input);
printf ("In hexadecimal, that is: %X\n\n", input);
return 0;
Oct 05, 2008 | Computers & Internet
16 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
