Question about ASUS VE208T 20 inch LCD Monitor
Why is my monitor shuts down after a few minutes of use?
Could it be the LCD screen problem? it looks as if there's no power connected to it. it works just fine a few minutes ago. i rarely use this monitor. it's not new either. got it like 2 years ago. never happened before and it had just happened today. can it be fixed?
    Problem Solver:
  • 24 Answers
It sounds like its shortiung out my freind Dust is a horrible little "feind" and is not computer/electronics freindly
Posted on Dec 10, 2014
4 Suggested Answers
SOURCE: I have a ASUS VW192T
I too have the same problem, the only way i found to go around it is too remove the power cable e plug it in again..But anyways, im taking it to assistance today
Posted on Jan 31, 2009
  • 152 Answers
SOURCE: LCD monitor shuts down every after 2-3 seconds
dustcore025, Need a little more info here. Do you know age of monitor? Was it or did it display a "perfect' image on it the day before? Is it under warranty? How far are you willing to go to try and repair this thing? Do you know how to "part" the snap together plastic back cover from the bezel, after removing the pedestal? This sounds to me like a Switch-mode-power-supply or Inverter problem that occurs when some Electrolytic Filter Capacitors get a little bit TIRED of being constantly subjected to high temperatures near heatsinks that are used to keep semiconductors within operating limits. You can determine how bad this may be if you can do a test and remember what happens. Here is what to do. Make sure PC is fully booted displaying WIN desktop or some other screen. Next, with someone to keep hitting the CTRL or SP bar key every 20-40 seconds while you reconnect both cables of your MM17 back to the PC video port and ac outlet. Now try to turn on the monitor and note exactly what you see and for how long. Did it have a sharp clear image, even for 1-2 seconds? did the screen go black? OK! Next thing is to shine a bright flashlight onto the screen 2 inches away from where you know there was something a few seconds ago. Try it at different angles and not if you see anything. get back to me with results of test. I'm louie12fix on fixya or lmistyrel @ aol.com BYE for now.
Posted on Apr 06, 2009
  • 11 Answers
SOURCE: Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Posted on Oct 04, 2009
Testimonial: "Thanks for a logical explanation. Appreciate it. However I think it is a problem with power a supply capacitor(I found it after some online research)"
Why is my monitor shuts down after just using it a few minutes?
This could be signal cross-talk from touching wires. Separate the wires in back.
May 07, 2014 | ASUS VE208T 20 inch LCD Monitor
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
Dec 08, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
My view sonic monitor is turned on and then in a few minutes it turns off leaving me a black screen. what can i do to fix it?
Sounds like overheating of something inside. Open the monitor, get access to PCBs and observe for darkened areas especially over the power supply and inverter. Also that long working before shut down may tell about bad solder junction, also caused by constant local overheating - look for those with tiny cracks, especially over darkened areas on PCBs.
Most likely - that's the source of problem with your monitor. And, as far as you open the monitor, check for any popped electrolytic capacitor - never bad to replace them too.
Sep 14, 2009 | ViewSonic VX1935wm LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Black screen
One way to test it is to connect a monitor to the VGA port (make sure to activate the external monitor (Fn+monitor key)
If it does work on the external monitor, I would look at replacing the onboard LCD.
If it doesn't, you are looking at problems with the onbaord video.
Aug 05, 2008 | Toshiba Satellite A105-S4334 Notebook
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Jun 19, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Mar 16, 2006 | ViewSonic VP191b 19" LCD Monitor
ASUS VE208T 20 inch LCD Monitor Logo
62 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
