Question about Mitsubishi WS-55511 55" Rear Projection Television
My mitsubish model ws-55511 has colors like im watching a 3-d movie. can anyone give me some help
  • 668 Answers
You have a failure in you Convergence circuit.
Probably a pair of STK-392-570's or a single STK393-110. These are common failures with this model series. I do however stress that the location of screws securing the board to the tray poses trouble getting the board out. I do recommend that a qualified serviceman do the job. You do not want to break the board because it probably is not available anymore through Mitsubishi.
I hope this helps,
skyassoc
Posted on Jun 22, 2009
Where is the reset button located on a mitsubish hb 1080 tv 2000
the WS55511 doesnt have a reset button like the DLP models instad you have to unplug the set from the wall for 5 minutes to reset it.
Oct 25, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 | Televison & Video
Tip
I hope that helps.
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The picture is bigger then the screen how do I adjust so that the picture is same size as TV thanks
Please confirm tv model number as question shows its Mitsubishi WS-55511 rear projection tv.
This info will help me to suggest a solution.
Do you get correct colors in picture though its over size?
Thanks.
Aug 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My Mistubishi WS-55511 will only show a blue screen for all possible inputs. Color is fine when I hit menu button. What could this be?
brentholt,
This model has a known deficiency. See my tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer for help finding parts and the procedure to repair your unit.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 29, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
CAN NOT FIX CONVERANCE RED & BLUE ON MY MITSUBISH HD 1080 SERIAL ws-55311 NEED A MANUAL ALSO
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
Dec 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green light blinks and cant turn tv on
If this is a WS-55511, it is probably caused by a DM module. Unfortunately, it is not available nor does Mitsubishi offer a rebuild option. Mitsubishi's phone# 1-800-332-2119.
Give them a call and you never know what they may offer you.
Hope this helps,
Skyassoc
Jun 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Help my ws-55511 can anyone help me with this.
Changing caps on DM board is good prevent maintenance,
 but does not represent the solution...DM caps symptom is
 Continuos blinking light.
 See    " problem 351"    On 10/20   WS 55908  comments.
  Let me know....T.
May 16, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
