Question about Craftsman 25cc Gas Line Trimmer
Weedeater won't starter - Craftsman 25cc Gas Line Trimmer
  • Jim Parker
    Jim Parker May 11, 2010
    Does it have fire (spark)? Jim
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Posted on Aug 25, 2009
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
Troybuilt weedeater Tb65 SS. The flywheel won't
INCORRECT PRODUCT CATEGORY
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 25, 2012 | Cars & Trucks
Ryobi 705R weedeater won't run. I can get it to
Yes, it is possible. Here are a couple of Tips to remedy your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
This should get it running for ya.
Good Luck!
Jim
Jul 24, 2011 | Tools & Hardware - Others
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
When I try to start my weedeater gas comes out of the muffler
It is flooded something fierce. The gas will come out of the muffler when it starts flooding the cylinder. Once you get it starter (no choke when flooded, throttle open) it will smoke like the dickens and then should be fine.
Apr 07, 2010 | Garden
WeedEater Edger PE550 Starter Rope will not recoil
Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
Aug 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Ryobi ss30 weedeater,if weedeater is flooded
If the spark plug is very wet, place the base of the plug against a metal part of the motor, with the sparkplug wire attached to the plug, and pull the starter rope, looking to make sure that the plug has a spark. If it doesn't, that is the problem and it may be that the breaker point gap has to be adjusted or the capacitor (condenser) has gone bad. It is not easy for folks with the typical tools of a homeowner to fix either of these problems, but it can be done. If the spark is good, pull the starter about ten times with the plug out to clear out the excess gas, dry out the plug and put it back in, then try to start it. Too much gas on the plug could indicate that you are pressing the primer bulb too many times or that the fuel adjustment is set too rich.
Jul 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
Craftsman 25cc Gas Line Trimmer Logo
722 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Mike Squire
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
