Question about Drills
How to replace sds chuck on hilti te16-c - Drills
2 Suggested Answers
  • 123 Answers
SOURCE: I need to remove the chuck assembly from Hilti
With the palm of your hand over the chuck where the bit goes in take your fingers and pull the black sleeve right at the drill casing and pull towards your palm. After you have pulled it all the way back just pull the whole chuck off.
Posted on Feb 07, 2011
How do i change the sds chuck to the standard chuck on an kango 220k hammer drill
do not think that is an option . get another drill with standard chuck .
Oct 05, 2015 | Hammer Drills
I have an SDS bit that will not release from my Hilti...any idea how to get it out?
by disassemble the chuck parts to get the ball out and all blocking parts , when the drive guiding the bilt lock is worn it will be happens again in a short time or you have used a wrong chisel ? the where safety glasses after the dissassembling and place the chisel with tool complete on it in a big bench vice and make the dissassembled bitholder hot carefully with a burner and beat the machine from the chisel only if all blocking parts are disassembled or totally removed replace the
chuck parts but also the entire shaft guide if it is simply worn out by wrong chisel not.
Jun 25, 2015 | Drills
It has broken chuck slot, need to be replaced
You can purchase replacement chucks from Hilti. 800-879-8000. Just put the end of the chuck in the palm of your hand. with your fingers pull the sleeve towards the palm of your hand. Then just pull the chuck off.
Aug 07, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Where can I buy replacement chisels? No one to have them for my unit.
SDS Plus is a common connection end. Several companies make them. I have not heard of a carbide tipped pointed chisel. only a carbide tipped chisel blade and bushing tool. Hilti makes very good chisels that will fit the Bosch. Hilti's number is 1800-879-8000
Jul 28, 2011 | Bosch Tools Sds Plus Hammer Steel Carbide...
How do I remove the sds chuck to fit the standaed chuck
The SDS chuck is an intergral part ot the rotary hammer drill assembly. You can get a standard chuck that has an SDS fitting on it and that will fit into your drill and give you standard drilling capabilities.
Mar 07, 2011 | Makita Garden
To install a driil bit?
Pull back on chuck u have to use sds type bit turn it till you feel it click in
Feb 15, 2011 | Hilti TE 70 Hammer Drill Performance...
I need to remove the chuck assembly from Hilti TE16 c
Feb 07, 2011 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
My hilti te-75 drills but is not hammering or will not go into chisel mode whay coud be the problem with it
Have seen this problem with some 'none' HILTI bits which do not fit correctly into the SDS chuck.
Tends to be with larger drill bits which have a wider shank than the SDS connector, the wider shank hits the end of the drill nose which stops the end of the drill bit contacting with the internal hammer.
Solution is to purchase original bits from Hilti. If you have OEM bits and chisel it will be another problem. Hope this helps.
Feb 07, 2011 | Hilti TE 70 Hammer Drill Performance...
'Whats the difference between a te c3x bit and a sds bit'
The difference is the type of shaft on the bit so that it matches to the chuck type of the drill...They are NOT interchangeable!!!!
You need to know which type of check your drill has and order accorndingly...
heatman101
Aug 25, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Drills Logo
41 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
