Question about Scuba Diving & Snorkeling
How to stop alarm on Aladin Pro dve computer
Problem solved with Aladin Pro alarm. Battery flat, needs replacement. Thanks.
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Need to replace DVE AC Adapter
If your desk charger is the version that can accommodate 2 units for simultaneous charging, any wall adapter would do as long as it is rated at 9VAC @ 450mA or higher. Since most wall adapters are DC output, you need to open it and remove the diode(s) and capacitor and connect the output of the secondary straight to the wires. Additionally, you need to get one whose plug will match the jack of the desk charger.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 23, 2008
SOURCE: saab vector car battery flat. removed battery. fob
pull the fuse
Posted on Jan 08, 2010
  • 60 Answers
SOURCE: Is the battery for the Uwatec Aladin Tec 2G 2
Unfortunately no it is not. Although it may be possible to do this yourself what the service centre will do is pressure test the unit after battery change to ensure that the computer is still accurate at depth and water tight of course. Hope that helps
Posted on Nov 08, 2010
Audi A6 (2004 estate) - installed a recharged battery and the signal/indicators stay lit, even when the car is driving, off and or locked. Is it an alarm reset issue?
Not familiar with your car, but, modern cars with computers don't take kindly to removing the battery. You should ALWAYS put a temporary battery across the posts to maintain the computer settings.
I suspect you'll have to go back to an agent to rectify this.
Apr 03, 2014 | Cars & Trucks
Is the battery for the Uwatec Aladin Tec 2G 2 Gauge Dive Computer Console - owner changeable?
Nov 07, 2010 | Uwatec Aladin Tec 2G 2 Gauge Dive Computer...
Extremely short battery life. How to fix?
Battery life is completely dependant on how often you use the computer to dive with. Batteries should generally be changed every two years regardless of use. An authorised dealer will also use the best recommended battery for the unit and not use cheap imported batteries. Hope that helps
Sep 19, 2010 | Uwatec Aladin Tec 2G Wrist Computer SCUBA...
I am looking for a wristband for a uwatec aladin prime dive computer, can't find it!!!!thank you for your time and wish you a good day.
Hello replacement wrist bands are available from any Uwatec stockist (They may have to order it for you) Try speaking to your nearest Scuba store. Hope that helps.
Sep 03, 2010 | Uwatec Aladin Tec 2G Wrist Computer SCUBA...
User manual needed
Bit confused by your question as you cant download a computer!! If your after the software for your Aladin try ebay or order it from any Scuba store that stocks aladin pro computers. Hope that helps.
Feb 20, 2010 | Scuba Diving & Snorkeling
Power outage last night - alarm sounded. Turned off computer - pressed the button to silence alarm. Five hours later, battery sounded a different alarm every 20 minutes that could not be stopped. Gr-r-r-r!...
hi..OK 1st step open the unit and find the memory from the board remove the memory then make clean the all pin connectors using a paper eraser.if u have video card remove too then same make a clean..good luck and have a nice day...Thanks
Jun 14, 2009 | Tripp Lite Lite OmniSmart 700 PNP UPS...
Jtrak software hangs during IR download
I'm afraid I can't solve our problem, but maybe you can solve mine, I'm in need of the drivers for the USB IrDA listed above, any chance of some help? Thanks.
Mar 20, 2009 | Uwatec Aladin Prime 3 Gauge Computer...
I have a car fitted with a Clifford GS 470 alarm but I cant get the alarm to stop. The car that this alarm was fitted in has not been started in 5 months and so the battery ran flat. I replaced the battery...
you might have to replace the batteries in the remotes. The reason why the alarm is going off because once you plug power back to the alarm brain it sets the alarm off and the only way to make it stop is to hit the unlock button the remote. Make sure all connections on the alarm brain are good and try changing the batteries in the remotes. also might have to reprogram the remotes to the brain if it has been sitting for awhile.
Feb 16, 2009 | Vehicle Parts & Accessories
Scuba Diving & Snorkeling Logo
55 people viewed this question
Top Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
