Question about Norcold Inc Refrigerators
Rv fridge works on gas but not on ac/dc what could be the cause
My rv norcold fridge stop cooling on ac/dc but it wil cool on gaswhat is the solution or what could be the issure have had tech out 6 times now and he can not fix thanks
  • 51 Answers
SOURCE: Dometic rv fridge
Your possibly getting a DC voltage interuption Your convertor can be over heating causing a temporary drop. You can chech this by turning everthing dc supplied on and watch to see if the check light comes on then. Primary is electric and if no electric then it is suppose to look for gas.
Posted on Sep 07, 2008
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
  • 68 Answers
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Posted on Mar 18, 2009
SOURCE: RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
  • 332 Answers
SOURCE: My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Posted on Mar 15, 2010
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Norcold model 1200LRIM. Unable to select AC or LP mode. Auto is only option. Fridge frequently quits in Auto mode. No error codes. Display just goes blank. Battery connections are good; voltage is good....
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Nov 21, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold N1095 model stopped working during very cold weather spell. No defaults codes at all showing--just will not cool down. AC and LP both work fine. Refrig just stopped cooling. Contacted norcold...
I have the same problem with my extra fridge in the garage. It has to do with the oil used as a refrigerant in newer models. The cold temprature thickens the oil and it stops cooling. Nothing you can do about it other than opening the door to the fridge to warm the insides up. It works for me. And thank god it's only when it gets very cold outside that this happens. Ps...my garage is insulated and drywalled and it still occors during cold spells.
Dec 17, 2009 | Refrigerators
Sep 09, 2009 | Thetford Norcold RV Cooler/Freezer
Freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Aug 19, 2009 | Refrigerators
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
My norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
Dometic rv fridge
May 29, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerators Logo
50 people viewed this question
Top Norcold Inc Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Norcold Inc Refrigerator Expert? Answer questions, earn points and help others
