Question about Hotpoint WMA40 Front Load Washer
Why did my machine fail to spin,after wash cycle,took half load out still no joy,then switched off, tried rinse and spin cycle still no joy, machine tends to spin for a few seconds, then stops, lights stay on, cycle end light does not come on. PLEASE HELP could the machine be confused ?
  • 209 Answers
SOURCE: HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Posted on Sep 27, 2007
SOURCE: fills washes rinses but wont spin properly or empty out
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Posted on Oct 19, 2007
  • 183 Answers
SOURCE: washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Posted on Dec 25, 2007
  • 1294 Answers
SOURCE: flashing power light and rinse hold light
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 26, 2008
barkencoa
  • 3463 Answers
SOURCE: wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Posted on Dec 11, 2008
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
My neptune washer will start and run about half a cycle and it acts like it gets stuck and on one cycle and never shuts off. I put a load of clothes in before I went to bed and next morning the machine...
What does half a cycle mean are you in Wash cycle, Spin Cycle? What does the Cycle Status LED indicate?
If you think the wash load is in a spin cycle of the wash cycle or rinse cycle place the machine in Spin Only cycle and see if it will complete.
Waht are your DIY skills? Do you want to try the repair/fix?.............Rich
Oct 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Final rinse cycle never engages
does all the water drain out? will the machine spin on any cycle? does the timer advance to off?
if the lid switch fails to activate then it would not let your machine spin on any cycle.
you should also check to see if cold water is coming into the machine. most machines rinse on cold water and if the water valve for the cold side fails - this could also be a cause.
May 29, 2010 | GE WDSR2080D Top Load Washer
Rise and spin
While the machine is operating take the timer knob and wiggle it around. If the machine cuts out momentarily then the timer is bad. If not then I would check out the lid switch to see if it is affecting the rinse and spin cycle.
Eric
Sep 17, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Hotpoint WMA40 Front Load Washer Logo
29 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
