Question about Smeg Classic Design 30 In. Stainless Steel Single Electric Wall Oven - SOU330X
What does error F13 mean on Smeg pyrolitic oven mean
2 Suggested Answers
  • 1462 Answers
SOURCE: meaning of symbols on oven setting.
i would know them if i were looking at it but hope this helps
line at top - top element only
line at bottom - bottom element only
line at top and bottom - conventional oven ie top and bottom elements on
wavy line - grill element
pic of fan - fan only with no heat
pic of fan with a line as well - fan oven
youi may not have all of these depending on oven.
best to use i find is fan oven - i do a lot of cooking!
Posted on Nov 05, 2008
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
Smeg pyrolitic oven is setting an alarm off on clock after we set the required temp it will start to heat up then the alarm goes off if not quick enough to reset clock, it then locks the oven door
in cleaning a pyrolitic oven is suppose to lock the oven door , this is a safety feature due to fact that oven gets up much higher in temp than a normal oven , the heated air it produces if let out would flash burn anything in front of it to ashes (people,pets,rugs,etc.) the clock doubles as your display window to see what temp oven is at , there should be a clock selection to see current time of day even if oven is in use , and last but not least , it has a delay cleaning start feature , you can set it to come on and clean it's self , Id recommend not to use this feature for safety reasons (I don't think the mfg thought that feature out too much )
the door should remain locked till oven temp is below a preset minimum safe temp ,id not force it open for safety reasons
Sep 28, 2015 | Smeg Ovens
Got error "pyrolitic interrupted" any way to clear this swithed of power for 24 hours to no effect
A feature of certain Smeg ovens, Pyrolytic cleaning is an automatic cleaning function which works by heating the inside of the oven to 500°C, at which temperature any grease stuck to the walls is simply burned off.
i think something is wrong with the elements
or a sender / sensor
so as its telling the controller for the oven that its not getting to the right temp perhaps one half of the oven isnt running etc
perhaps some sensor has become worn at these hi temps i cant see a senor lasting more than a few years before it degrades
May 05, 2015 | Ovens
What does error 8 mean?
Same problems, error 4 followed by error 8 on smeg oven SFP496X-1
The cooling fan had stopped working.
I fixed the problem by replacing the 20W ceramic resistor connected to the fan.
The spare parts number maybe 806890480
an image of resistor
Sep 24, 2014 | Smeg SE399X/5 Stainless Steel Electric...
Smeg linear oven is displaying sho (showroom mode) and will not heat up. I have held down function knob for 5 seconds which clears SHO from display but within seconds it comes back. Any ideas
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 28, 2013 | Smeg Linear Pyrolitic Single Oven Electric
I have a Smeg SA 398x model. firstly, I would like to know the year of manufacture please. Secondly, for some reason the fan element options do not heat up. The fan in the back of the oven works but no...
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
Jul 19, 2011 | Smeg Linear Pyrolitic Single Oven Electric
Getting an F13 error message on my stand alone professional series oven smooth top, how can this be corrected?
F13 does indicate you need to replace the electronic oven control. It means EEPROM/ Checksum error. If you have unplugged and it returns, this is a bad control board.
I hope this helps.
Apr 21, 2011 | Ovens
I have a new (about 7 months old) SMEG SAP112-8 60cm Linear Pyrolytic Oven. The knob to turn the oven on does not seem to work. You usually push it in (and meet some resistance) to turn the oven on, then...
We have experienced the same problem. We have a service tech coming to fix it. The knob has come off. It seems that the internal spring has dislodged itself. This will be claimed under warranty. Ours is 5 months old. Our other Linear combo oven and coffee machine seem to be more solid/sturdy.
Dec 24, 2010 | Smeg Linear Pyrolitic Single Oven Electric
Error f13 on my frigidaire oven how do i fix it
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power did not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
Feb 19, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Smeg Classic Design 30 In. Stainless Steel Single Electric Wall Oven - SOU330X Logo
89 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Smeg Oven Expert? Answer questions, earn points and help others
