Question about SanDisk Sansa e250 MP3 Player
Low power i had the e250 given to me by a friend but he had lost the cable for it. i went out and bought a new one and when i went to charge it up all the power that was in it was taken and now when i try to turn it back on it just says and is very hot to touch. did i do something wrong? thanks for any help
  • wyattsmoma Nov 06, 2007
    Not the same but Similar... I lost my chord and now I am having Issues with the new one... Didn't notice a temp change in my Player though. I have not found many with even similar issues... I am really starting to wonder if its in the Chord that is the problem... It will charge mine ( same Chord) through the car USB adaptor I have ( cigarette lighter to USB hub, only for charging) But wont on the computer... Any ideas are welcomed here!!!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
Key won't turn in ignition on 2006 chevy cobalt
on a lot of these late model computer base cars when battery power get low the computer gets confused. try this disconnect the neg. battery cable. charge the battery. reconnect and try again. my son cobalt battery went bad key was stuck in the igntion. good luck.
Dec 19, 2017 | Chevrolet Cobalt Cars & Trucks
I lost my usb cable where can i get another one?
http://shop.sandisk.com/servlet/ControllerServlet?Action=DisplayHomePage&Env=BASE&Locale=en_US&SiteID=sdiskus&resid=S3x1MQoBAkcAADtaE@sAAAAR&rests=1266447664839
that site should help
Feb 17, 2010 | SanDisk Sansa e250 MP3 Player
I have the same problem Xbox controller flashes once then nothing
you need to push the sync button on the xbox and then on the controller if that doesnt work you controller is faulty
Aug 29, 2009 | Microsoft MS Xbox 360 Common Controller...
HTC touch will not turn on
Hello friend. i am having the same mobile and had a same problem while i let it charge the whole nit and in the morning it never boot. its the battery problem. change the battery or get one of ur friend same kind of battery and boot with it. it will boot. cheer up the battery has gone. the problem is the new battery wont avail for this model. i tried a cheep one that little bit solved the problem but the talk time comes to very low. original battery must be replaced. best of luck.
May 28, 2009 | HTC Touch P3450 Smartphone
Can't charge my sansa e250
My suspect is the cable. I think testing it on a friends cable or if you go in an electric shack, there you should check out the symptomes. In the case it works you should buy a new cable or check in the guarant. If i doesn't work in my guess only the guaranty will work because I guess this isn't due to external damage.
May 24, 2009 | SanDisk Sansa e250 MP3 Player
Significant volume decrease when using Comcast cable box
This low audio problem happened to me suddenly yesterday. I powered off over night - no change. I plugged the A/V cables into a second TV - no change. I called Comcast - problem solved.
Tap these buttons on the remote;
May 16, 2009 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
Charging pro
I believe the cable is the charger. I have an e250 which charges from the computer. Simply connect the player to the computer using the cable, and when the player is detected by the computer - it is charging!
My friend have a different charger though, but she bought it from the store.
Mar 27, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
T831 polaroid camara
mi camara no salen las letras esta trabada
Oct 15, 2008 | Polaroid i832 Digital Camera
Sansa e250 mp3 player
Yes I have How do I fix it
Dec 18, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
