Question about Brother DCP-8060 All-In-One Laser Printer
Where are the mirrors situated at need cleaned to stop grey copy?
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 150 Answers
HIGH VOLTAGE POWER SUPPLY IS DAMAGED
Posted on May 08, 2014
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
How to stop backgrounds being printed when i copy something
The optics are dirty.Use a flash light and look at the optics on the printer.I'm sure you will see their dirty.Remove glass ,Clean the mirrors in the scanner cavity with a moist cloth.Don't scratch or press to hard the mirrors are brittle.
Apr 09, 2013 | Epson Stylus CX9400 Photo Printer
Handheld 4cycle blower stops after 5-10 min- hard to start then- starts ok when cold-oil a little low & grey
Address the oil situation immediately. Oil should never look "grey" in color. Get the proper weight of oil for the machine. I recommend synthetic always be used. Advance Auto Parts sells synthetic under their store brand, comparable in cost to name brand conventional oil. Keep a close eye on the color and level of the engine oil. Synthetic will clean the engine real well, so be prepared to change it again.The machine is probably stopping because it is getting hot from poor lubrication.
Jun 08, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
How do i clean my canon pc 921
these isnt toner problem. The toner when is out, gives light pictures.
These is optics problem or drum unit problem.
You need to clean beneath copy glass, clean mirrors on scaner rail assy, and beaneth zoom lens cover.
If the problem still occurs replace drum unit. Beare in mind that you after replacing of drum unit must do initialisation under service mode.
Jul 21, 2010 | Canon PC-920 Black and White Copier
Toshiba e-studio 3511 has printing issued on one
These copiers have serious toner dust issues. Light copies are usually caused by dust in the optics (the mirrors) and on the laser glass.
Take off the main copy glass and gently clean all the mirrors and scan bulb underneath it - be careful.
If you remove the drum unit and look inside the cavity you took it out of you will probably find a huge toner mess. the laser glass is situated in this cavity and needs to be cleaned - just clean whatever you can see...
Feb 01, 2010 | Toshiba E-Studio 3511 Color Copier
HP Officejet J5780 All-in-one Injet prints a grey line down the right side of the page when copying using the automatic document feeder. It does not show up when printing; and it does not show up when...
lift the feed area and look at the small glass plate where the auto feed paper is actually scanned. That needs a good cleaning. Since the paper runs across it even a tiny little obstruction such as paper left from a paper jam or a dot of ink from that pen you used to unstick that last paper jam (maybe its just me??). That one dot turns into a line when the paper rolls across it. Clean well and the line will dissappear.
Feb 27, 2009 | HP Officejet J5780 All-In-One InkJet...
Sharp 2700N has gray bands on copies
Hi
be very careful you could cost your self allot of $
If the grey band moves it could be 1 of 2 things 1st try cleaning the fuser section be careful it is very hot, and if you not familiar with this you may want to find a service provider, it can get a little tricky, 2nd it could be the Drum cleaning blade and the drum need to be replaced. if you take the drum out this also can be very tricky. It sounds also like it may just need to be cleaned like the mirrors and platen.
Good Luck
Jan 28, 2009 | Sharp MX-2700N Color Copier
Cannon PC1061 making dark copies
OR you can do it yourself.
your problems seems to be Dirty Mirrors.
Your copiear has 6 mirrors that need to be clean up. 5 of them are kinda easy access. the other needs to be clean thru something thiner than your fingers. (you can see the mirror but no way you can reach it).
Now dont worry (not yet) about that 6th mirror since THEORICALLY it doesnt get dirty.
So try first to clean up the other mirrors. and see what happens.
They are located below the platen glass (remove it) and be careful with the lenses (do not touch them). clean everything that seems to reflect light Or images.
If nothing changes you may want to try out with a new cartdrige. Your drum may be done.
Oct 19, 2008 | Canon PC1061 Copier
Grey paper on copy.
unfortunately this is not a fix yourself problem.
1- seperation could be bad
2-bad toner or developer
3- could be as easy as cleaning the mirrors
try to find a tech that works on the side, or freelances for no more than $40-75 depending on the complexity.
Aug 08, 2008 | Ricoh Aficio 450 Copier
Brother DCP-8060 All-In-One Laser Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
