Question about Cell Phones
K222s phone not start ! msg illigal restart
Hi,i had a problem with my nokia n73,it always showed a msg that "phone memory is full delete some data"....i tried to change the phone to its original settings from...
switch off ur phone
press
calling button{green button}and
perss on off switch{switch on ur phone}
press contiune they four key
if not come on display
formatting
then formetting ur phone
or select ur country or language
set time
date
ur fault
will solved 10000000%
its my gurrenty
note:
{the work will start full bettry}
idrish 911
Oct 28, 2010 | Nokia N73 Cellular Phone
From last fews date my n73 not started whenever i m trying to restart it show a msg"phone start failed contact to retailer
this is a firmware/software problem; you have to reflash/rewrite it;
maybe a retailer cand help you or search a little on the internet
also, you can try ovi suite to upgrade your phone
Sep 10, 2010 | Nokia N73 Cellular Phone
When i start my nokia n97 up i get a msg asking 'use phone in offline mode?' than boots up offline. shortly after msg displays 'insert sim card' and than 'phone will restart?'what is the problem here? i...
actually there is a problem with either ur sim card or ur phones sim card slot
1. Try putting some other sim card and donot use ur phone in offline mode .
2.If u still have the same problem then there is a hardware problem go to nokia
Jan 20, 2010 | Nokia N97 Cell Phone
Sometimes i cant receive msg. and i have to restart it so that i can continue receiving msg.
your phone needs software and calibration. then the problem will be solved.
Jun 15, 2009 | Samsung SGH-J750 Cell Phone
Nokia 5610 security code locked
contact service provider the code is 12345 and if the problem isn't solved with the reset than download the firmware update form Nokia.com or get it form the Nokia service center for free this will solve the problem.
Jun 15, 2009 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
When sending a text msg, it goes to outbox, wont send
I had the same problem and I read on down and saw someone's phone was stuck in flight mode. I remembered that for some reason, my phone was in flight mode the other day, so I went in and took it off. I realized the problem had been since that time. So, I put the phone back in flight mode and was able to delete the message from my outbox. I put it back in normal mode and now I can send texts. Yes!!!!
Nov 29, 2008 | Sony Ericsson w580i Cellular Phone
Unlock the phone
i need to restart the n73.because folder off msg is now shore cut.and any msg what i rcvd,a canot see.pls help
Sep 20, 2008 | Nokia N73 Cellular Phone
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
