Question about Kodak EasyShare Z740 Digital Camera
Why does my Kodak easy share Z740 printer all of a sudden only print the bottom part of the pictures? other than this problem I am very pleased with this product, this happened after I bought new printing paper
  • 790 Answers
You can search around this link for more information on resetting your camera
Posted on May 07, 2014
  • 31 Answers
SOURCE: Kodak EasyShare Printer Dock Series 3
If the boundary between the blank half and the printed half is a sharp line, a wire to the print head may be broken or disconnected. If the boundary is irregular (wanders up and down an 1/8 inch or so), the problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
Posted on Mar 20, 2009
  • 9 Answers
SOURCE: My kodak easy share z1275 wont power on. I have
read this post, worked for me!
http://www.fixya.com/support/t3489422-camera_will_turn_second_go
Posted on Dec 11, 2009
SOURCE: Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
Posted on Apr 12, 2010
rajdeepdutta
  • 2517 Answers
SOURCE: z740 easy share will not power up,tried new batteries ,nothing at
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format.
Posted on Jun 08, 2010
  • 356 Answers
SOURCE: i just bought a c195 kodak easy share
You can view the extended manual at:
http://support.en.kodak.com/app/answers/detail/a_id/19314/selected/true
You can also download it as a PDF if you wish.
Please leave feedback if this was helpful. Thanks.
Posted on Mar 25, 2011
We have a Kodak Easy Share Z740. It was working fine and all of a sudden it quit transferring pictures over to the computer. It will not bring up the Scanner and Camera Wizard. Can you help?
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sep 28, 2010 | Kodak EasyShare Z740 Digital Camera
Kodak easy share series 3 , only prints lower portion of picture.
Try reinstalling the printer driver. If that doesnt help, try a hard reset: Unplug the printer from AC power and PC, wait about 10 minutes and retry.
You can also do an alignment test. If none of this proves succesful, you either have a bad print head, or problem in the circuitry, which will need servicing.
Jun 24, 2008 | Kodak Office Equipment & Supplies
How can I print pictures from internal memory
In the menu, there should be an entry for "copy" giving you the option to copy the internal memory to a memory card.
Jul 03, 2010 | Kodak EasyShare Z740 Digital Camera
Kodak Easy Share z740 won't format Kodak Memory
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
  4. Scroll up or down to the Format option, then press the OK button.
  5. Follow the prompts to format the memory card.
Retrieved from www.kodak.com.
Mar 29, 2010 | Cameras
Kodak Easyshare Z740 printing problems
In order to help you with your printing problem I need the model of the printer and not the camera.
If it helps here is a link to the online printer help tool:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
I hope it works out
Feb 07, 2010 | Kodak EasyShare Z740 Digital Camera
All the pictures in my kodak easy share program are coming up with a x in the thumbnail. How can i get the pictures back Thanks
Did you move the pics to another location on hard drive? The Easy Share program is just tool to view the pics that are stored on the hard drive. It uses "Albums" to view these pics. The Album is still there but it sounds like the pictures got moved.
Feb 24, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak EASYSHARE Printer Dock
Well it's not looking to pomising by reading all of the other people who are having the same problem. But could you please tell me how to fix my printer in is only printing half of my pictures no matter how many times i reprint them and it also doesn't pick up the printing paper very well i have to help it along. So if you could PLEASE tell me how to fix this problem on my own it would be greatly appreciated. Please respond As Soon As Possible Please and Thank You. I have the Kodak Easy Share Printer Dock Series 3.
Patricia Davis
Nov 03, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
Printing pictures on Kodak Printer dock G610 from Kodak Easy Share on the computer
keeps giving me message "printing error" (prints ok from camera) i have probably messed up every setting by now
Oct 20, 2008 | Kodak EASYSHARE G610 Thermal Printer
Kodak EasyShare Z740 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
