Question about Creative Labs Zen Digital Media Player
Tt'll try to load a song (and will then crash.
The screen doesn't really "freeze" in that the back-light still comes on when you press buttons and the name still scrolls across the screen.
However, the screen is frozen on that song. I can't change songs, the song won't play either, and I can't exit from that screen. When I try to shut it off it won't shut off. I reset it a couple times and each time it worked for awhile afterward then the problem came up again.The last time I reset it it said "Firmware Error" and now it won't turn on or anything. I've tried reloading the firmware and that doesn't work.
    Sergeant:
  • 220 Answers
Maybe the file itself is corrupt.
Have you tried with other files?
If you did and they played well all you have to do is to get the song again
Posted on Jun 22, 2009
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Firmware reload
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
Posted on Jan 23, 2008
SOURCE: Firmware Reload
well, after a lot of research and frustration, I found a site that had links to the right firmware versions so I could fix it! I also had to dig into the pit of despair that is my storage bins and thankfully I was able to find the CD that came with my DJ to give my computer the drivers it needed to recognize the DJ...
http://www.gotzune.com/forums/showthread.php?p=60383#post60383 go to that link and look towards the bottom for the link to your version of firmware that you need... ftp://ftp.dell.com/app/R74011.exe <--- that one worked for me!
thankfully, I was able to fix it by doing that, but not before I had to delete all the data from it in a sad attempt to make it work when it was stuck in recovery mode :( but I have all the good stuff on my computer, so it's probably better that I cleaned it up because I had too much **** on there that I didn't listen to anymore...
b
Posted on Dec 11, 2008
shadow83
  • 496 Answers
SOURCE: firmware problem
you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. so you'll want to run the flashing utility and that will do the rest just make sure thats the only program your running at that time if your system freezes up durring this processe then you could end up with a dead mp3 player or a fancy paper weight
Posted on Oct 07, 2009
glwoods1
  • 80 Answers
SOURCE: reloading firmware on creative zen
Do you mean you want to update the firmware? Or your player is frozen?
If frozen, there's a hole in the left side of the device, the restart button is in there, find something thin enough and push it.
To update your firmware, go to www.creative.com and download the latest firmware installer, dock your zen with your PC and run the installer, following it's instructions as you go.
Posted on Mar 06, 2010
GPX 2G mp3 player -
I plugged it to my computer and when it connected I pressed and held the m button for about 10 seconds and then i unplugged it from the computer and turned it on and now it dont freeze on my 3rd song! I had 20 songs on there but i couldnt move from the 3rd song! I couldnt go back or forward to the next song before i tried this method! I hope this helps!!
Feb 09, 2012 | GPX MW240 MP3 Player
Just bought the Docking Station for the EVO 4g but it just freeze's my phone how do I install it correctly?
If your phone is working correctly, you just plug the phone into the docking station, no extra steps necessary. If, however, the app that runs the docking station thing that comes up is having issues, it'll freeze the phone. If restarting the phone doesn't fix it, then you'd need to perform a hard reset, which would delete everything on the phone. If you want to do this, back up all your data, turn the phone off, and then hold down the down volume key and the power button. After a few seconds, a screen with 3 skateboarding Androids will show up. Once it loads, a menu will show up, with one of the options being "CLEAR STORAGE". Use the volume keys to highlight it, and use the power button to select it. It will then ask if you want to delete all user data. Press the volume up key to do so. Once the phone starts back up, it will be back to the state it was at when you bought it. Set the phone up, put it in the dock, and if it still freezes, you're going to need to take it to a Sprint store to have them either fix or replace the phone. Be sure to remove the SD card if they end up replacing it, as the new phone will not come with one.
Jul 18, 2011 | HTC EVO 4G Smartphone
I'm trying to add music and videos
Xbox 360 1) Insert the Music Disk into the 360.
2) A screen should appear with it showing a visualization picture and showing the tracks (songs).
If it doesn't appear, go to the dashboard scroll across to the Multimedia section and go to Music.
3) Up the top of the screen it says options like "Burn and Rip".
Choose "Rip" and it'll copy the songs from the disk onto the 360. Give it time to finish.
4) And it should say your done. And it's saved onto your 360.
To listen while playing; When you are in the game, press the xbox guide button (the X button in the middle of the controller that has the green light) and wait till that screen pops up on the side of the screen.
Then Scroll down to where it says (I think it says Music) but you'll see the "Pause, Play and Skip etc... music buttons, and choose "Select Music" and then it'll expand and take you to the music library (In your hardrive) And just choose the song.
And it'll take you back to the gamer tag picture, like before, and press the Xbox guide button and you're back to your game - while the song plays throughout.
And it wont take you away from your game.
Hope I helped ?
Playstation 3 ok, you can put music from a cd onto a ps3. heres how.
put the cd you want into the ps3 then go to music then go to audio cd. instead of x to view the tracks hit triangle and select copy. the ps3 can take songs from a cd and put it on the hard drive
you can take songs from the computer and put it on a ps3, heres how.
first, you need a flash drive (if ur not tech savvy, its a lil usb thing that holds information. make sure its a decent size ( 1gb would be best but more or less is ok). then go to my computer on the computer and you should see removable disk. click that. now drag and drop all the songs you want to move to your ps3. once ur done, take the flash drive out and put it in the ps3. go to music and select usb device, however hit triangle and hit display all and it will show you all the music files. hit triangle again and select copy multiple and get all the songs you want from the flash drive
and yes, you can download songs from the internet of a ps3, heres how
heres some of the sites i use
mp3realm.org yourmp3.net emp3world.com
find a song you like and click the song link. when you do, hover over the link and hit triangle then go to file and select save target. certain files cant be downloaded because keep in mind that it needs to be an.mp3 file for it to be directly downloaded and ready to use (and since you cant rename files on a ps3, you can always download it to a flash drive and change the file name on the pc and then put it back on the ps3)
Jun 14, 2011 | Video Game Consoles & Games
Ipod touch NO SOUND! and also CRASHES when on Sleep
try contacting apple and ask them. you might wanna recycle it and get a new one
Mar 21, 2010 | Apple iPod touch Second Gen (8 GB,...
Acer Aspire 5920 laptop is showing blank scren w/blinking cursor
yea yur harddriv crashed... try formattin yur drive and create a new partion and load OS .. if it still doesn work then yu ll have to replac yur drive..
May 01, 2009 | Acer Computers & Internet
My screen froze on my ipod
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Apr 05, 2009 | Coby MP-705 Digital Media Player
Songs dissapeared!
Several things. 1. To correctly reset it, flip the lock button, then hold down the power button. 2. Format your sansa. Make sure you have all your stuff off. Then, format it. If you don't know how, e-mail me here : spazzysmash@gmail.com Then sync it back on!
Feb 08, 2009 | SanDisk Sansa e250 MP3 Player
After downloading 28 songs it freezes up!
i have no idea but mabe try to down load a little at the time or press the reset button and try again if not sorry if i could not be of any help.
Oct 05, 2006 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Creative Labs Zen Digital Media Player Logo
69 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
