Question about Asko XXL Series D5434XXL Full Console Dishwasher with 14-Place Settings, 6 Wash Cycles, 7Spray Wash System, Turbo Drying System, Delay Start and 48 dBA
Detergent compartment not opening during wash
We put a tablet into the compartment and during the wash the door doesn't release so the detergent tablet remains inside.
  • 641 Answers
SOURCE: Detergent Door not Opening
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. In case it will not solve your problem, you should replace the wax motor that operate the cup door. Good luck
Posted on Aug 27, 2007
  • 14 Answers
SOURCE: Detergent lid won't latch shut
The whole dispenser will need to be replaced, they only come complete
Posted on Sep 08, 2007
  • 351 Answers
SOURCE: Asko D1996 Stainless Steel Detergent Door Does Not Open
the pcb will need replacing,the dispenser gets its power from there.
Posted on Mar 02, 2008
  • 490 Answers
SOURCE: The washing machine doesn't open if I use detergent
read the side of the detergent box it normally says how much, and your washer is probably not opening because it has lid lock to open it you need to pause the cycle and wait a few minutes and it will release the lock also if the washeer is spinning or agitating the lid will automatically lock to open do as described above
Posted on Feb 19, 2010
heatman101
  • 43501 Answers
SOURCE: The soap isn't emptying out of the compartment
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Aug 05, 2011
ADP 4730
The problem is with either the spring or the solenoid that operates the detergent compartment door. It should be released at the right time by the controller during wash cycle. You have to check the spring and see if it stuck. But if solenoid is faulty then whole detergent dispenser has to be replaced. You could switch to detergent tablet which you drop in the cutlery basket and it works fine. A brand like Finish works well and keeps dishwasher clean.
Alternatively you can purchase a replace detergent dispenser from
http://www.buyspares.co.uk/whirlpool/adp4730-851150429849/dispenser/product.pl?pid=18330&path=463858:496324,47872:463870&refine=dispenser&model_ref=641830
Also watch the video on how to replace.
Apr 23, 2014 | Whirlpool Dishwashers
The detergent compartment on our dishwasher will open during operation. We have run the dishwasher three times and the detergent capsule remains in the compartment and is only partially dissolved. It...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
Apr 18, 2011 | KitchenAid Dishwashers
The main wash door doesnt open
switch to pre-measured tablets,and throw the tablet directly into the tank(d/w..)it works better that way anyways...most dispensers are very expensive also
Mar 03, 2010 | Dishwashers
Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Jan 22, 2010 | Zanussi Dishwashers
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Help i need to know were to put the detergant
Detergent usually goes either as power or tablet form into the little compartment fixed to the door.  The compartment itself has a flap which keeps the detergent in until it is required in the wash cycle.
Jan 27, 2009 | Dishwashers
Tablet falls out & doesn't dissolve especially on fast cycle
Hi and wlecome...
You should not use anything other than powered dishwasher detergent in these products. They are not designed for tablet-style detergents. The reason is because the dispenser does not "open" during the wash cycle like you would see on a conventional dishwaser. The incoming water pours over the detergent and releases the mixture out the bottom of the dispenser. If you need a user guide, you can get one here: http://fisherpaykelparts.net/index.php?blockitemid=29
Jan 22, 2009 | Fisher and Paykel 23 in. DS603H W Built-in...
GE Triton XL
Try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not disolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
Aug 28, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
Asko XXL Series D5434XXL Full Console Dishwasher with 14-Place Settings, 6 Wash Cycles, 7Spray Wash System, Turbo Drying System, Delay Start and 48 dBA Logo
64 people viewed this question
Top Asko Water Dispensing & Filtration Experts
ray gallant
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Tom Chichester
Are you an Asko Water Dispensing and Filtration Expert? Answer questions, earn points and help others
