Canon ir2016 Hi my canon iR 2016 is printing feint on the upper tray but if i use the bottom trays is working proper. help pls
  • 790 Answers
Try this. Remove all the paper from trays and inspect for paper in corners or stuck under rollers.
If possible, give it a good blowout. and re-assamble.
Posted on May 07, 2014
damanpreet_c
  • 69 Answers
SOURCE: Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Posted on Nov 12, 2008
fer_nan_14
  • 76 Answers
SOURCE: copier model canon ir 2016 (down load stand by )
hi if yo have knowledge on electronics try to remove the boot rom and memory and let the machine for 10 minutes,then put it back the memory and boot rom,and turn on the machine.if the same thing try to update the firmware using sst
Posted on Mar 06, 2009
SOURCE: Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Posted on Apr 09, 2009
SOURCE: canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
Posted on Apr 20, 2009
  • 16 Answers
SOURCE: Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
Posted on Jul 15, 2009
Service Manual with error codes for Canon IR 2016
Hello friend, you can find the canon iR 2016 service manual in below link:
Canon iR2016 iR2020 series service manual:
http://goo.gl/L6QGlk
Good luck on repairs.
Aug 28, 2012 | Canon Office Equipment & Supplies
Is the Duplex facility is available in Canon IR 2016
Hello,abila,
The Canon IR2016 "I" model has duplex capability aleady built in. The IR 2016 does not but it is available as a seperately purchased add on. It's not hard to put but the instructions (included) is a bit confusing.Once you have succesfully installed the duplex unit you will probably want to put the instructions at the bottom of your bird cage. But an end user should be able to figure it out with patience.The catalog number for the duplex unit is 0418B002AA. And the 0 in the front of this number is important.Good luck and please let "FIXYA" know I helped you. SPINAL
Feb 18, 2011 | Canon iR 2016i Black and White Copier
I cant complete the intallation of Ir2016 printewr driver-no usb port is detected
Do you have plain model with marking ir 2016 or 2016J or 2016i
Plain model does not have print option, network is optional and usb port is there for system upload.
Aug 09, 2010 | Canon iR 2016i Black and White Copier
I have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
May 29, 2010 | Canon iR 2016i Black and White Copier
Canon iR2016 PCL5e A4 copies have suddenly started to print out in landscape, regardless of any buttons pressed. This means all copies are coming out portrait shape but only printed across the middle. Any...
Check and make sure the paper setting is on what it thinks it is. In other words, make sure the the paper in the tray is letter and the display says letter, instead of letter-r (letter-r runs the long way from side to side in the tray, and letter runs the long way from front to back in the tray) or any other size. I am not familiar with the set up of the paper trays on that machine, but if you have to program the paper size yourself, make sure it is what it is.
Oct 27, 2009 | Canon iR 2016i Black and White Copier
Canon ir2016 TROUBLESHOOT printer problem
Hi mate,
Prior to the issue you facing currently seem like ,
1)have u put the printer driver as default.
2)have u point to the correct printer port at the driver.
3)at the driver advance setting ;get the device status then reboot the machine .
GOOD LUCK MATE......Kindly RATE ME!!! Thanks YOU.
Sep 26, 2009 | Canon ImageRunner 2016 Copier
Showing change paper size when select LGL size paper in canon ir2016
If you are selecting legal on the screen to copy, then be sure that you have legal paper in the tray for printing and that any tray guides are properly set to reflect this.
Jul 22, 2009 | Canon Office Equipment & Supplies
Canon copier iR2016
My Canon copier IR2016 Problem code E007 Solve the problem pls
help me
Mar 02, 2008 | Office Equipment & Supplies
46 people viewed this question
jasbo
jasbo
