Question about Saeco Coffee Makers & Espresso Machines
Temperature error saeco idea
Temp error
2 Suggested Answers
SOURCE: Temperature control on Saeco magic deluxe
boiler is trip after one minute due to temp. meter setting is wrong how can i manage its.
Posted on Jan 13, 2013
Can anyone assist with an out of service #36 on a saeco 200 series coffee machine
you make sure if the resistance of boiler is ok
. this error cames when the temperature is not stabile
Jan 20, 2015 | Saeco Coffee Makers & Espresso Machines
Hi temperature
Hi
In your menu there is a setting for temperature. You can raise or lower the temp. There is also a cup temperature setting.
Jun 28, 2010 | Saeco V-spresso Espresso Machine
Saeco Magic Deluxe temperature control. can this unit have the water temp increased
Hi
Yes it can, but it takes a special computer that plugs into the back of the power board in the machine.
Aug 15, 2009 | Saeco Magic De Luxe Espresso Machine
No it cannot. I am not sure why you would want the water hotter. It is designed to be at the perect temperature for passing through the brew group for coffee brewing, its kind of a simple science.
If your machine has been producing less hot coffee gradually, that marks an issue. Try descaling the boiler per the manufacturer's inscrutions even if the warning light isnt on. The other option is that the thermal fuse mounted to the boiler is bad and turns off the boiler prematurely, those cost about $15 and are simple to replace. Lastly, the boiler heating element may be 'burnt out' new boiler is $120+
Frigidaire oven F-10 error
HI. this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
May 24, 2009 | Frigidaire FGB24S5A Gas Single Oven
Slow and low heating/temp
When a machine takes a longer time to heat up, this is often due to scale on top of the heating element, try using a descaler product, and running a descale cycle a couple of time.
If it is not a scale problem, then it is usually a faulty thermostat or a faulty element.
When it is a faulty thermostat water gets hotter than normally.
Nov 22, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Cafe Charisma
no! the max temp is pre set to about 90oC to 95oC on the p.c. board. any higher temp will cause the the coffee beans/grounds to burn, thus BAD TASTING coffee , according to most experts (barrista)
Feb 08, 2008 | Saeco Caffe Charisma Espresso Machine
Water is not hot enough for tea
Try using the cup heater to warm the cup before hand. Use a thermometer to measure the temp of the water coming out. If it doesn't reach 80 degrees, then the thermostat may need to be replaced.
Dec 14, 2007 | Saeco Royal Professional Espresso Machine
Coffee Makers & Espresso Machines Logo
65 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
