Question about Stoves Heating & Cooling
How is E6 error on Fisher & Paykel induction cooktop fixed?
How is E6 error fixed?
3 Suggested Answers
  • 30 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
Posted on Jun 08, 2010
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Posted on Dec 21, 2010
Induction cooker are display E6 error
I did exactly the same thing as "Carol Johansson" did to fix her "Electrolux" induction cooktop.
My "Omega" induction cooktop was intermittently (more often than not) coming up with error E6 problems on two of the four elements, after a power reset it started to do it on all 4 elements.(Now the Boss was not happy)
I pulled it all apart taking photos of every stage of dismantling, makes it a lot easier to put it all back together.
The main power supply board which supplies the other two boards has about six electrolytic capacitors, two of them where bulging, (curved on the top instead of being flat). They where the 470uF 25V ones, I replaced them with 470uF 35V ones from Jaycar for $2.80.
Put it all back together and we can eat tonight, Boss is happy!!
Hope this helps and thanks to Carol for pointing me in the right direction.
May 11, 2016 | Cooktops
E6 error code on fisher & pykel single door dishwasher
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 2 of 3 for Mitsubishi Electric Cooling & Heating - Duration: 2 ...
LG Control Panel Overview
www.lg.com > ... > Repair > Locate Repair Provider
LG ElectronicsAn OE error code indicates the washing machine is draining slowly or not at all. This is usually ... When you see the E6 error icon, it means there is a clutch error.
Nov 19, 2015 | Fisher and Paykel Dishwashers
What does Error E 6 on my Fisher and Paykel induction cooktop mean?
The cooker has been incorrectly connected.
The appliance should be connected to the
appropriate power supply by a qualified
technician.
Please see this link for more information
May 07, 2014 | Heating & Cooling
Induction error e6
check your earth connection
Jul 18, 2013 | Cooktops
Induction error e6
Hello it07002 - You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and/or user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
May 07, 2013 | Electrolux 36" Electric Hybrid Induction...
Fisher & Paykel Dishwasher DW60CEX1
My Fisher and Paykel dw60cex1 is displaying an error of E6??
Feb 22, 2012 | Dishwashers
E6 fault unable to reset all cycle lights showing
E6 is "Flood switch activated."
Turn the water off and disconnect power to the dishwasher, then empty water from the inside. Clean drain well and check the drain hose at the back. If that does not work, then the water pressure switch is at fault. Call your Fisher & Paykel dealer or Authorized Service Center.
Dec 06, 2011 | Fisher and Paykel 24 in. DS603MFC Built-in...
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
Mar 23, 2011 | Microwave Ovens
Whirlpool induction ceramic cooktop error E6
Dec 15, 2009 | Cooktops
Heating & Cooling Logo
366 people viewed this question
Top Stoves Heating & Cooling Experts
Paul Carew
ghold1
Level 1 Expert
vance jones
Are you a Stoves Heating and Cooling Expert? Answer questions, earn points and help others
