Question about Furniture
Baumatic bwc600ss Showing e4 on display
2 Suggested Answers
SOURCE: e4 shows up when i turn on my dishwasher
E4 is an overfill code caused by water pressure problem.
On the base of the unit - (underneath the kitchen plinth) there are 2 black plastic clip panels - each these of with a blunt knife or screw driver and turn off the appliance at the mains. In there you will see lots of wiring etc. Simply get a dish cloth and mop up any water that is in there, particularly at the back left as that is where the sensor that detects the over flow is. Its simply a rubber valve that is boyent and so lifts when water is present. then once most of the water is removed, turn on.The problem would be solved.
TO PREVENT THIS HAPPENING - when you take off the kitchen plinth you will see 2 small clear pipes in the centre - between the 2 plastic panels. These are cable tied. Simple cut the cable tie and feed the pipes out of the dishwasher - place a bowl under tehre if you whish. This will prevent overfloww water enterin the base. BE WARNED BY DOING THIS THE DISHWASHER WILL NOT HAVE ANY OVERFLOW PROTECTION CAUSING POSSIBLE DAMAGE TO KITCHEN AND APPLIANCE. My advice would be to leave it in place but try to prevent overflow - i.e rinse plates first or try a different brand of wash tablets. If it does happen then the fix is simple and you definately do not have to remove the unit as many people imply.
Posted on Jan 20, 2009
Baumatic bdw14 e4
already addressed in next post on this topic.
Apr 25, 2014 | Baumatic Dishwashers
What does the code E4 mean on the display
This is an overfill error code. this is a common issue with this machine. here are some discussions about this issue. Remember to turn off the power at the circuit breaker box before you sick your hands inside. The posts are
here and here
hope this helps
Jan 13, 2011 | Baumatic 18 in. BDW45.1 Built-in...
Error code e4
This might be a re-badged generic dishwasher - on my Baumatic E4 error caused by floatswitch in bottom catch tray. Some (supposedly small amount) water collects here and should evaporate naturally. If it accumulates, float rises and stops machine.
TURN OFF THE POWER
try to find a way into the machine base catch-tray to sponge it out - on the Baumatic there are two large black plastic plugs on the front of the machine base that can be forcibly flipped out.
failing that, take machine out and tip it up to get rid of water
Oct 09, 2008 | Maytag Dishwashers
Baumatic BDW13
e4 code means the machine is showing a fault code for overfill,tip the machinee to a 45 degree angle and get excess water out should run ok after that
Aug 13, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Code E2 showing in temparature display
I contacted the technical team at www.baumatic.co.uk and here is the reply I got.
-----Original Message-----
From: Samantha.Codd@baumatic.co.uk [mailto:Samantha.Codd@baumatic.co.uk] On Behalf Of Technical@baumatic.co.uk
Sent: 25 January 2008 13:02
To: Taline Bedrossian
Subject: Re: BWE40 wine cooler
Good Morning.
Thank you for your e-mail.
This error code means that your appliance has experienced a defrost sensor
fault. Please contact our service team on 01189 336 911 to arrange a
suitable time for an Engineer to visit you.
Kind Regards
Quality and Technical Department
Baumatic Ltd
www.baumatic.co.uk
Jan 19, 2008 | Baumatic BWE40 Wine Cooler
E4 error message
take off two black covers on bottom front of machine and mop up or soak up any water you feel or see at very bottom of machine by a polystyrene float this will fix it
Dec 27, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
BDW45.1 Baumatic Dishwasher E4 alarm
Check and clean the filters on the inlet water line (both sides). Good luck!
Sep 03, 2007 | Baumatic 18 in. BHD45 Slim-Line Built-in...
I need to reset my dishwasher but don't know how!!
If it's any help then here is the link to the user manual (when you download it it applies to bdw13 as well even though it is labelled for the bdw14) http://www.baumatic.co.uk/products/discontinued-models/dishwashers/integrateddishwashers/BDW14 Best I could come up with is to try page 19 at the bottom of the "dishwasher doesn't run" section - there are two different types of reset which may do the job. Hope this helps :)
Mar 13, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Furniture Logo
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
