Question about Korg PS60 61 Portable Performance Synthesizer KEY ESSENTIALS BUNDLE
How do I open up keyboard to replace the power supply input jack
I need to get inside to replace power supply input jack
2 Suggested Answers
  • 790 Answers
SOURCE: what screws need to be removed to get inside the keyboard to replace power supply input jack
Flip the keyboard on its back and remove all screws with an arrow.
If no arrow, remove all on outside edge.
The jack should be easy to replace but you may need a soldering gun.
Posted on May 07, 2014
My Casio ctk 811ex wont power up anyone more.Is there an internal battery that needs replacing ? What could be causing the problem ? 2 weeks ago it was working fine
ALWAYS start with the "easy" things 1st. Is the AC outlet on the wall working properly? Is the "wall-wart" power supply working correctly? If no defect is found, check the DC power jack located on the rear of the keyboard. Does it seem to be loose or does moving the power supply jack up/down cause any change? New wall-wart power supplies can be purchased from Radio Shack and usually at a lower price than the original factory replacements.
Mar 29, 2015 | Casio Music
After using two applicable power chords the keyboard will not turn on
Assuming that the adapters are 12v negative(-) center and an incorrect positive(+) center was never used. That would cause a shorted diode in the power supply. The next most common problem would be a cracked trace or solder joint inside the keyboard at the power jack. Other problems require more detailed troubleshooting. A wire soldered across the cracked trace(if that is the cause of the trouble) is relatively easy if you own a soldering iron. If not bring the keyboard to a technician.
Oct 11, 2014 | Casio Cdp-100 88 Note Digital Piano
What screws need to be removed to get inside the keyboard to replace power supply input jack
May 07, 2014 | Korg PS60 61-Key Performance Synthesizer
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
I need to install a standard 1/4 phone jack in series with the 2 headphone jacks that are on the left front of my Yamaha P 70 electronic piano. Where can I get a schematic diagram, and a disassembly or...
What you are requesting will not work as you expect. The easiest way to achieve what you seek is to utilize what is called a Direct Box. This is essentially an external transformer that isolates the keyboard from any attached equipment (to eliminate grounding hum) and will allow you to conenct an XLR (low impedance) cable to the keyboard. I assume that you wish to attach the keyboard to some type of sound system which is likely to have standard XLR Mic inputs.
Update this with any additional questions that you have. Please note that using the direct box (about $20-$40) will be both the easiest solution as well as prevent the need to modify the keyboard.
Dan
Oct 18, 2010 | Yamaha Full-Size Keyboard
I have NS-2 Noise Suppressor Pedal, this works fine but in some moment make a radio noise (hum) and the output signal comes down (like turns the volume to 0) ... I don't know what it is, I'm going to...
The probable problem is poor connections at the input and/or audio output jacks.
Usually the power supply will fail either on or off which is sometimes cause by a bad input power jack.
In any case, the problem is likely internal and will require repair.
Aug 06, 2010 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Amplifier not working
The Cube 60 is a guitar amp, Often these problems are due to a damaged inout jack on the unit. People trip over the guitar cable and the cord gets yanked sideways and breaks the internal parts of the jack. Sometimes circuit boards are cracked.
ALWAYS run your cord through the handle or restrain it should the cord be yanked.
The problem with your unit is internal and it will need to be opened and trouble shooting done.
Dec 15, 2009 | Music
BOSS DD3 STAYS ON AND WILL NOT TURN OFF
It's supposed to do that. An extra lug on the input jack is connected to the battery and/or power supply's ground.
So the only way to power off any pedal is to disconnect the input jack. If you use a power supply and power multiple pedals you can simply disconnect the power supply to cut power and avoid unplugging each one.
Oct 08, 2009 | Boss Music
Power input needle snapped on Casio CTK 1000
The answer is repair shop if you don't have tools or experience with soldering. If you do it is simple to take it apart and take the old supply jack out. Take it to an electronic parts supplier so they can match a new one up for you. Make sure that the holes in the circuit board are clean and free of broken pins. Make sure that the traces leading to the holes are intact. Do not use too much heat or they will separate from the board. It might help to take the adapter with you as the jacks and plug have to match in size.
Aug 04, 2009 | Music
Feedback overpowers amp output...I have fixed my guitars, fixed and replaced chords, tried other amps, tried other guitars, and nothing seems to fix the problem...If there a way to switch polarity on this...
Hi there. If there is still feedback with nothing plugged into the amp, the problem is internal to the amp. Probably worn input jack or intermittent connector internal. Try thumping on amp with nothing hooked up. (guitar)
Thanks
Paul
Jul 03, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Korg PS60 61 Portable Performance Synthesizer KEY ESSENTIALS BUNDLE Logo
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
