Question about Philips 100 ft. 16 ga. Speaker Wire - CONSUMER ELECTRONICS B.V
Turntable running faster after changing the belts
Hi all, After replacing both the belts of my Philips ga 242 found the rpm is too fast. Need help to fix
  • 790 Answers
I have found a link to give more information on speed control and new belts
Posted on May 07, 2014
The speed switch results in same slower speed than 33 rpm when set to 33 or 45, and 78 is slower than 78 rpm, but faster than 45 rpm
Assuming it is a belt driven turntable I suspect the belt has slipped out of position. It might need adjusting or replacing. If you do need to replace it make a note of how it fits, even though it could be in the wrong position. It's a starting point for putting the new one in the right position.
Dec 28, 2015 | Audio Players & Recorders
Turntable running slow
Hi Ken,
it is a Technics Frequency Generator Servo (Belt drive SL-23). I have four different belts and neither one of them works. Two are too slow and one is too fast and the other one is slow and fast.
I changed the belt before that I got off of an old turn table. It deteriorated.
I would appreciate any help.
So far I am also having Gateway Monitor problems and Canon Mp560 printer problems
Thank you,.
Aug 23, 2014 | Audio Players & Recorders
Turntable has stopped working, possible belt stretch
I don't think it's likely that the motor is in trouble just by having the belt wrong. It would require more physical damage to cause the motor to play up. Having said that the motor could have been in trouble before you touched the belt. But you do need a new belt, all you need to do is measure the diameter of the belt in mm. You might also need to measure the width. To find a new belt put the words "turntable drive belt XXmm" into Google. You can add Crosley to the start, but many belts are universal. Your measurements don't need to be spot on with the diameter, so if you have measured it at say 95mm, a 90mm to 100mm belt will do the job. However fitting the new belt is a different matter. You need to know the correct way, or the speed might be wrong. I can't help you with the fitting of it, so you will need to check how to do it. Some makes have YouTube videos of the fitting. I would just look for Crosley and see if any look like your model.
If fitted correctly and there's a problem with speed still, then you should look more closely at the motor.
Mar 26, 2014 | Crosley Stack-O-Matic CR40 Turntable
Would changing the belt help as my turntable plays too fast.
A lot of turntables have two belt positions on each pulley. One for 33 and one for 45. I would check to make sure the belt hasn't slipped into the 45 position.
Jan 13, 2013 | Audio Players & Recorders
Turntable stops intermittant while playing
The belt on the player is gone and has to be replaced. I have the same problem with the same model and I'm looking for belt myself. All the best.
Dec 10, 2008 | Audio Players & Recorders
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Turntable Spinning too fast
ya buy new belt loose or is this direct drive
Oct 09, 2008 | Teac GF-350 CD Shelf System
Turntable plays too fast
I have seen this problem before. Lift the turntable off. It might be held down with a clip around the center pole. Under it you will see a wheel that contacts the turn table and the center shaft of the motor. The motor shaft has 3 0r 4 elevations with different diameters. When you change the speed the wheel will move up and down to different diameter levels on the motor shaft. It must be free to move. It might need some oil at the moving parts as I suspect it is not moving properly.
Hope this helps.
May 08, 2008 | Teac SL-A100 Shelf System
Plays too fast
I had this same problem. You can adjust the speed, although it is a bit of a pain. If you turn the unit over you will see two little holes on the bottom labeled "33" and "45". You will need a small (jewelers) flat head screw driver. If you put the screw driver in the hole you will encounter a rubber cover. Push the screw driver through the rubber and go down a bit further and you will feel a screw. Turning this screw to the left (counter clockwise) makes the speed slower. Turn the screw to the left to make the speed faster.
For a picture you can download the service manual:
www.eserviceinfo.com/downloadsm/24072/Aiwa%20Service_PX-E860.html
You can check the speed visually by downloading a strobe disc (I found one I like at http://www.extremephono.com/free_turntable_strobe_disk.htm). To actually be able to see the strobe you need to do this under a lamp with a single fluorescent light bulb (fluorescent bulbs actually flicker a little bit at the same frequency as the electric supply).
Oct 31, 2007 | Aiwa PX-E860 Turntable
Started playing too fast, now won't turn
Check that the belt has not perished.
Oct 06, 2007 | Philips WMM142211 Turntable
Philips 100 ft. 16 ga. Speaker Wire - CONSUMER ELECTRONICS B.V Logo
51 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
