Question about Kenmore 63942 Dryer
Gas dryer heats for couple minutes then goes cold
Dryer turned on sometimes wil heat for couple minutes then goes cold sometimes does not heat from get go this ison all settings
    Sergeant:
  • 212 Answers
Sounds like gas valve is not opening. your ignitor has to pull 3.2 to 3.6 amps to open gas valve. check amps
Posted on Jun 22, 2009
My gas dryer will ignite and stay on with the flame for only a short period of time every time i start it it will light but withen a couple minutes it goes out.any help?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 11, 2011 | Roper RGX4634KQ Gas Dryer
Dryer spins but wil not produce any heat to dry clothes
heatman101
Dec 16, 2010 | Frigidaire GLER341A Electric Dryer
My gas dryer heats a little for a minute sometimes, then turns cold for hours. Could this still be the igniter ?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Dec 15, 2010 | Whirlpool LEB6300 Electric Dryer
Dryer gets hot for a couple of minutes then goes cold
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 02, 2010 | Maytag MGD6400T Gas Dryer
My dryer wil not heat in any cycle
heatman101
Sep 12, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Turn dryer on runs about 1 minute gas goes off what could be the problem
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 06, 2010 | Kenmore Dryers
Roper RGX5634KQ2 Dryer will fire initially, and heat up. It will stay fired up for around 1-2 minutes, and go out. After another couple minutes, the igniter fires, but there is no flame. This continues...
Could be a coil...but I have learned that it usually is the ignitor...
heatman101
Sep 02, 2010 | Roper RGX4634KQ Gas Dryer
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Running the dryer with normal settings. Dryer runs, tub spins, but NO HEAT. Error code popping up after a couple of minutes is "Ad". Any ideas on what the issue might be?
heatman101
Aug 23, 2010 | Frigidaire AEQ6000ES Electric Dryer
Inglis gas dryer heat loss
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 04, 2009 | Dryers
Kenmore 63942 Dryer Logo
381 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
