Dawlance AC Swing Motor Manuals - Heating & Cooling
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
H6 error dawlance ac
check all your connections in the wiring. also get a new touchpad and replace it.
Feb 15, 2014 | Microwave Ovens
Dawlance split air conditioner shows the eror in display f6
Check the condensor fan motor. If less RPM replace capacitor. still continues, replace f.motor.
Aug 25, 2012 | Dometic Heating & Cooling
Dawlance monogram error code e5
P1 error code in dawalance inverter
Jun 12, 2012 | Heating & Cooling
Natures touch cradle swing---please advise where batteries are located so we can change them
4 "D" cell batteries are located in a compartment in the swing motor housing. This is the unit at the top of the triangular swing assembly.
Here is a website with manuals. See page 12 of the pdf.
May 10, 2011 | Fisher Price Baby Care
Baby swing......graco doesn't swing
I had the exact same problem the motor worked fine but when we took it apart the gear inside was stripped. i hate saying it but best thing you can do is buy a new swing. i personally recommend http://www.toysrus.com/product/index.jsp?productId=3420749&camp=PPC%3A204318389. its a little bit high but so worth the money. my 8mo old baby girl loves it. it also has a AC adapter so no more batteries and an ipod hook up as well so you can pick what music you want your baby to listen to. best of luck.
Mar 29, 2009 | Baby Gear
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
