Question about Garden
Xtreme pressure washer keeps cutting out. - Garden
    Scholar:
  • 90 Answers
If it is a gas powered machine and it cuts out when you release the spray gun trigger, it means that your unloader valve is stuck closed.
It would help to have more information about your machine and your problem. Gas or electric? Does it start up and run fine or cut out a few seconds after starting? Does it cut out when you release the trigger?
Does it cut out while spraying?
Posted on Jun 12, 2014
you have to be more specific in your questions. Is this a gas or electric machine? What happens when your machine fails? Does it spray fine for awhile and then cut out? Does it cut out when you turn it on? Give us symptoms .
May 07, 2014 | Garden
Hotpoint wt960 keeps displaying f05
Seems that the pressure switch is jammed and so it does not cut off supply or is cutting off inlet water to the washer. Remove the lines to the pressure switch and reset, check the pressure switch diaphragm
Click pressure switch
Error codes for Hotpoint
Jan 20, 2013 | Washing Machines
Challenge xtreme 2000w pressure washer manual
Hi I have a challenge extreme 2500w pressure washer. it's tree years old , hardly used. I have come to set it up, but seem to have no power or start up after switching it on. any advice would be greatful?
Jul 01, 2012 | Garden
Fix soap dispenser on xtreme dw-1840 bv pressure washer
it will only draw soap when your using the large fitting they don't draw with the high pressure nozzles
Mar 22, 2012 | Garden
D link DI624 router keeps cutting in and out...
1. Check the router for the current firmware version
2. Check the manufacturer for the current firmware updates.
May 20, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Im having a problem keeping the motor running. it cuts off and will re-start easily and run in the choke mode? won't run in the normal mode until i cut it off and re-start. then it will run for about 5...
Hello. Your carburator is gummed up. Get a can of seafoam fuel additive at the auto parts store and put the recommended amount into the gas. This will clear up the problem in just a few minutes. Joe
Mar 16, 2010 | Northstar Pressure Washer 3000 PSI
Pressure washer keeps cutting out
Carb problems: needle seat is sticking!
Dec 08, 2009 | Garden
I have a craftsman 4.5hp quantum xte pressure washer 1800psi/4.5hp/2.0gpm mod 580.761800. I have to start the washer before I turn the water on and just today started with if I let go of the trigger on the...
the pressure relief valve(bypass) is most likely stuck or clogged. take the relief valve off and check for broken or jammed parts..there should be a bypass hose that goes around the pressure valve
Jun 16, 2009 | Briggs & Stratton Garden
Garden Logo
270 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
