Question about Nixon Watches
Minute hand is loose
Minute hands moves freely
SOURCE: Ta Heuer Professional stopwatch minute hand reser to 12 position
pull the crown on first click and push the upper button until it reaches to your desired position.
Posted on Mar 20, 2008
VOTIT
  • 2071 Answers
SOURCE: hour and minute hands dont move, second hand does
You better go to a watch service center to replace depected parts ,the problem of your watch is a broken center wheel,need to replace with a new one with identical size and caliber,so its works normal again.
Hope it may help you;
Regards;
VOTIT
Posted on Apr 23, 2009
  • 2976 Answers
SOURCE: Casio Lineage Waveceptor 4717 minute hand off by 20 seconds
You would have to remove the movement from the case, remove the hand and reinstall it, to where you want it.
Posted on Aug 06, 2009
SOURCE: the minutes hand stuck at a position
Hallo have you found what was the problem?
I have the same with mi EF 529D watch the minut and hour hand are not moving at all.
Posted on Feb 11, 2010
  • 2501 Answers
SOURCE: Watch hands don't coincide with the digital time.
This usually occurs when the battery is changed. There should be a process for synchronising the two times detailed in the manual.
To get a manual you go to "http://tissot.ch/" and on the black menu bar at the bottom of the page you will see "product support". Click on this and you will go to a page of instructions. Download yours and find the relevant method for putting your watch right.
Posted on Apr 30, 2010
Testimonial: "You were right. I downloaded the manual and the synchronisation instructions were there. Still not sure how it happened. But thanks so much!"
Sir..my casio watch second hand isnt moving suddendly and the minute hand is moving freely.
Hi Sanen
What model is your Casio watch?
For what you describe it would appear as if there is a problem with the cockwheels assembly on your Casio watch. Most likely as a result of a severe impact. hard enough to dislodge the retaining plates or break of the bottom of the minute hand spindle.
Hope this helps
Dec 19, 2016 | Casio Watches
On my casio edifice 4334 module and the digital works fine but the analog i can see the minutes handle trying to move but not succeeding , seems to me like it is stuck thanks in advance.
Check if the battery is still in good condition. If this doesn't solve the problem, swipe a magnet over the back of the watch in different directions until the minute hand moves. Take care not to scratch the watch with the magnet. It may be necessary to oscillate the magnet several times at the correct position and direction until the minute hand moves freely.
Sep 26, 2015 | Casio Watches
The hour hand doesn't move
try opening the glass over the hands and pressing down on the hub of the hour hand
they are a press on fit with slots cut in the sides and will slip if the hub is loose on the hour shaft
place the minute hand and the hour hand at 12 o'clock first so that the minutes will always be in the right position on the hour.
Jun 21, 2015 | Home
The minute hand spins freely. how do i fix this?
Your hands need to be reset. It is possible that you have dropped your watch or have knocked it on something to make them come loose. You need to take it into a jeweler or a watch repair person to have it fixed because they will need to open the watch up to solve the problem.
Oct 04, 2013 | Fossil CH2331 Wrist Watch
TW Steel unable to reset minute chronograph hand (small upper left dial) I know how to reset second hand crown out push upper button etc but how do I rest minute recording hand
If the reset procedure still fails on time and date set crown positions together with chronograph buttons, and the minute counter doesn't move even when the stopwatch runs, the following can be tried:
The minute counter's motor may be stuck. Swipe a magnet hence and forth in different directions close to the back of the watch until the minute counter moves. The other hands may also move, but they can be reset later. Continue swiping several times to loosen the motor. A sheet should be placed behind the back of the watch to avoid scratches. Once the motor is loose enough, it can be further loosened by using its reset button which will spin it around when depressed.
Aug 25, 2011 | Kenneth Cole KC1232 Wrist Watch
Minute hand spins freely,if you shake watch
mcdevito75 here, Sounds like the minute hand is loose on the minute gear shaft. Look for a small watch repair shop in your araea for repair.
Aug 20, 2010 | Timex 27191 Wristwatch
Mintues hand problem.
There are two reasons for this. First- you distorted minute hands hole and now it is not sitting tightly on pinion. Second- when you pulled off the minutes hand, you lifted cannon pinion. As the result it is loose and swings freely. I do understand you have no knowledge how the watches are build, so, visit your nearest watch repair shop and ask to fix it. Please, do not take it personally - it is just because you can't do that without watchmakers knowledge, so, save your nerves, time and watch. Rate me, plz.
Mar 18, 2010 | Timex 27191 Wristwatch
Casio watch
Press MODE until you reach H-S (e.g. A 11:00 with seconds on top)
Press and hold ADJUST for 3 seconds until H-S blinks
Press and hold SEARCH for every movement; you may wanna press LIGHT so the hands will move freely. Press ADJUST again to when desired time was reached
Oct 21, 2008 | Casio Watches
Rolex ladies DayJust
No problem pulling it the way out its okey,Wind it the crown until calendar move so the hands move properly.When you going back the crown,push the crown hardly going inside while pushing, wind the crown until you reach the end so its locks properly,because has a thread needs to lock so it will not wind freely,that all Working guy, txt me whatever happen.
May 02, 2008 | Rolex Daytona 116520 Wrist Watch
Watches Logo
94 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
